Re: Gen III Hemi, please post things to avoid and know..
[Re: ntstlgl1970]
#1906715
09/05/15 02:35 AM
09/05/15 02:35 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Darius has been struggling to get his car driving right, he is in the same car club as me. To my knowledge he is not running the NAG1 as a stand alone....
The NAG1 is the same as the mercedes transmission that they use in a bunch of different chassis with a different id - I think it's called a 722.6 or something like that.
Quick followup on the NAG1- I talked to Darius at Sac raceway last weekend and he finally got his trans sorted out, its not a stand alone controller though. Biggest problem is just chrysler not wanting to support these types of swaps by sharing data like GM and Ford do.
[Re: Chris'sBarracuda]
#1920432
09/27/15 01:48 AM
09/27/15 01:48 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I had not seen that, thanks Chris
"Just a Bracket car dressed up like a streetcar"
[Re: Street Monkies]
#1921011
09/28/15 01:24 AM
09/28/15 01:24 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Roughly what is the cost to build one of these engines for drag race use? From low to high cost. Depends on your HP target. Buggest inhibitor is the crappy slugs, piston/valve clearance and rods - so with an unopened motor I dont think youd see much more than appx 520 fwhp NA with a 6.1' ported heads, cam, headers, tune and modded intake.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: Just-a-dart]
#1921039
09/28/15 04:53 AM
09/28/15 04:53 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I had not seen that, thanks Chris Welcome Don.. I just noticed that I didn't title it.. DONE.. Chris..
[Re: gregsdart]
#1933826
10/17/15 03:05 PM
10/17/15 03:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Eagle 65cc 6.1 73cc Whichever ones you have use, or get Apaches.
Mopar to the bone!!!
[Re: gregsdart]
#1939169
10/26/15 07:57 PM
10/26/15 07:57 PM
Triple Threat
Renton Washington
If using a 6.4 apache head on an early 5.7 block what head gasket is needed? 5.7 bore is likely too small, will the 6.4 work? 6.1?
[Re: gregsdart]
#1940174
10/28/15 05:57 AM
10/28/15 05:57 AM
Posts: 10,179 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I was told to use the gasket that matches the block. As far as bore goes, there must be an after market gasket that will work. Guys have bored the 5.7 to 4.00. According to a picture of Apache heads sitting on a 5.7 un bored block, the chambers on the Apache heads are small enough to work with a 4.00 bore gasket.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#1940362
10/28/15 01:33 PM
10/28/15 01:33 PM
Triple Threat
Renton Washington
Cometic 5.7L gaskets are 4.100 bore, so should be good there.
[Re: gregsdart]
#1941152
10/29/15 05:15 PM
10/29/15 05:15 PM
Triple Threat
Renton Washington
All 6.1's use the same head, its just known as the 6.1, no code name.
[Re: WO23Coronet]
#1941161
10/29/15 05:28 PM
10/29/15 05:28 PM
Posts: 8,954 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
They're just called 6.1 heads, no fancy name for them, still a good head, flow #'s comparable to an Eagle head Do they have problems with seats popping out?
[Re: WO23Coronet]
#1941425
10/29/15 11:31 PM
10/29/15 11:31 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I don't think so, it's the early 5.7 heads that we're known to do that, and generally (but not always) only if they were heated/ran hot Think it was over reved and broke top of lifter. Looked in pushrod hole with bore scope, saw seat beat up
[Re: gregsdart]
#2034203
03/18/16 11:18 PM
03/18/16 11:18 PM
72Swinger
Nebraska
It is a BFNY build, IIRC Eagle heads, 12.1 and a decent cam.
