Re: Gen III Hemi, please post things to avoid and know..
[Re: cudaman1969]
#1858962
06/28/15 03:32 PM
06/28/15 03:32 PM
Posts: 3,111 old westchester
mcat4321
old westchester
Two questions, any problems putting the 6.1-6.4 crank in a 5.7 block,maybe cam line up? Next, how or what is used to mate the 904-727 trans to the 5.7? 5.7 is an 2007. i am pretty sure a 6.4 crank will not fit in an 07, the 07 does not have vvt and a 6.4 crank snout is longer. i am 100% possitive though a 6.1 is identical to an 07 5.7 except it is a steel crank not cast like a 5.7..
[Re: cudaman1969]
#1858976
06/28/15 03:46 PM
06/28/15 03:46 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Two questions, any problems putting the 6.1-6.4 crank in a 5.7 block,maybe cam line up? Next, how or what is used to mate the 904-727 trans to the 5.7? 5.7 is an 2007. No problem with 6.1 to a 5.7 block, same crank different material. 6.4 machine the front of the crank to fit in an 03 to 08 5.7 or any 6.1 block. Very simple procedure. 904 to 727 will bolt up. I believe the top hole on both trans is not used. IIRC you will need a ring gear same as a Chevy. I believe mopar sells them. Matt
[Re: gregsdart]
#1859079
06/28/15 06:48 PM
06/28/15 06:48 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The 5.7 2009+ and 6.4 2011+ are both VVT engines which have the timing set spaced further from block face and use thicker timing covers to accommodate the the VVT setup. All 6.1 cranks will work in ALL engines with 2 caveats, For use in VVT engines, you need a crank sprocket spacer. Also 6.1 cranks use a unique to them,4 bolt IIRC, trigger wheel that you need to make sure has the right tooth count for your type of engine management. To use a VVT crank in a non VVT engine you would have to have it machined to let the crank sprocket seat deeper on the snout.
Mopar to the bone!!!
[Re: gregsdart]
#1859091
06/28/15 06:58 PM
06/28/15 06:58 PM
Posts: 12,532 Kalispell Mt.
HotRodDave
Kalispell Mt.
You can bolt up the 904/727/518/a500 SB trans by using a 02-08 flex plate and a jeep converter or knock the ring gear off your existing converter. I have not run it but looks like it will all be spaced out the same.
[Re: gregsdart]
#1859440
06/29/15 12:53 AM
06/29/15 12:53 AM
72Swinger
Nebraska
340Rick on here has already done this, I cant remember him having any issues at all. His car flys too.
[Re: gregsdart]
#1859555
06/29/15 10:51 AM
06/29/15 10:51 AM
Posts: 154 Plano, TX
StricNine
Plano, TX
If you get a crankshaft for/from a manual transmission engine the pilot bearing (p/n 53009180AB) will have to come out. The parts manual shows a sleeve (p/n 4736283AA) that I suppose is for the torque convertor snout.
StricNine
79 Li'l Red Express, 15.04 @ 89.57 09 Challenger R/T, 11.95 @ 115.92
[Re: gregsdart]
#1860763
06/30/15 06:46 PM
06/30/15 06:46 PM
HotRodDave
Kalispell Mt.
I have an 11 an 03 and 2 04 truck and durango engines and none of them have that ring and the converter from a 727 and 904 fits in there just fine, may just be a car thing for the car trans.
[Re: HotRodDave]
#1860974
06/30/15 11:11 PM
06/30/15 11:11 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I think you are right, the trucks didn't get the NAG-1 *except the jeep SRT8 I think* and the pilot on the NAG converter is pretty small. The rest of the trucks I think had the 545RFE. Maybe that is the reason for no sleeve. The flexplate I got from mancini racing looks just like the ATI in the picture above. The midplate I used measured about .090" the dowels still had enough engagement to line up ok
[Re: ntstlgl1970]
#1861281
07/01/15 01:29 PM
07/01/15 01:29 PM
Posts: 8,954 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I think you are right, the trucks didn't get the NAG-1 *except the jeep SRT8 I think* and the pilot on the NAG converter is pretty small. The rest of the trucks I think had the 545RFE. Maybe that is the reason for no sleeve. The flexplate I got from mancini racing looks just like the ATI in the picture above. The midplate I used measured about .090" the dowels still had enough engagement to line up ok Sometimes things hit you in the face like steeping on a rake. I can see now why the 727-904 fit the blocks because it was basically the same trans used in the trucks and the Nags in the cars, so simple a cave man should know. Probably the first time Chrysler has done this.
[Re: ntstlgl1970]
#1861393
07/01/15 04:20 PM
07/01/15 04:20 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The sleeve has to come out of the crank to fit the large pilot on the 904/727/518 transmissions. Also, you would need to check the converter engagement depth if using the MP conversion flexplate (no ring gear) as it was with mine, there was almost 0 free play so I had to shim the transmission back (used a mid plate and cut off the extra) to allow for converter movement and not kill the thrust bearing or the front pump. The bushing is made out of some pretty hard stuff, took a while to get it out. I would suggest a mock up outside the car. I too had to shim my block and trans with one converter but didn't have to with another converter. I didn't bother trying to figure out why this was the case but I have seen a lot of posts where some guys say the needed to shim and other said they didn't
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: gregsdart]
#1862949
07/03/15 04:34 PM
07/03/15 04:34 PM
72Swinger
Nebraska
I have my gauges independent from the EFISOURCE.
[Re: hudsonhornet7x]
#1862970
07/03/15 05:28 PM
07/03/15 05:28 PM
mcat4321
old westchester
Here is a new question:
When putting a Gen III in an older car, with something like MS3 EFI, What gauges can be used and do you wire them to the block, or the EFI and Ignition? Things like oil pressure, voltage, water temp, etc. i run my factory 1968 senders in the block and use factory gauges. i also monitor everything efi on my cell phone using shadow dash
