16 foot open trailer and A body???? #1862378
07/02/15 10:19 PM
07/02/15 10:19 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I bought a nice used trailer from a trailer dealer and brought it home today.
In my excitement I didn't pay a lot of attention to how long it was.
Well, it's 16 foot with a 4 foot beaver tail on it.
Looks like my Duster will fit on it..... Hopefully... But won't know for sure till I load the car up late tomorrow afternoon.
I have 16 foot that is flat. Anybody had such a trailer before. Think the one I had few years ago must have had 18 foot that was flat, and was fairly roomy as I remember.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862395
07/02/15 10:40 PM
07/02/15 10:40 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I had a 18 ft. ( 16 flat with 2 ft. dove tail) and I hauled my 71 Demon on it with out any problems.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 16 foot open trailer and A body???? [Re: D-50] #1862486
07/02/15 11:59 PM
07/02/15 11:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
hauled my 73 charger on a 16ft econo trailer
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862490
07/03/15 12:05 AM
07/03/15 12:05 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
It will fit!
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862524
07/03/15 12:43 AM
07/03/15 12:43 AM
Colorado Springs, Colorado
Dartthunder340 Offline
I used a 16' for a few races, my Dart fit with no problems. The one I used did not have a dovetail though, so I had to use ramps under the truck to get enough for clearance.
Better get inside Ma. Looks like a storm's comin'.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862529
07/03/15 12:53 AM
07/03/15 12:53 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Towed my 70 dart on a 14' trailer. It was tight. 16' should be fine.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862539
07/03/15 01:15 AM
07/03/15 01:15 AM
The Duster and other short wheel base A bodys are 108 inches which is 12 ft. ,correct? So your fine as far as it fitting on your 16 ft long trailer properly, make sure and get the center of gravity on the car loaded forward of the center of gravity on the trailer so it will tow easily without swaying scope I know guys that have used 1000 lb wharehouse platform scales under thier front trailer nose wheel disconnected from thier trucks to see how much tongue weight they where putting on the trucks towing hitch, they would move the car to get what they wanted and then put marks on the trailer so they could put the car there every time from then on upIHTHs up
Re: 16 foot open trailer and A body???? [Re: dustergirl340] #1862615
07/03/15 03:24 AM
07/03/15 03:24 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By dustergirl340
It will fit!
up with room to spare, i haul my B body on a 16' trailer.
72 Plymouth Roadrunner 11.08@123.25
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1862749
07/03/15 12:00 PM
07/03/15 12:00 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
You small block guys crack me up getting all giddy ---- haha haha haha
over the length of it ----- whistling
Re: 16 foot open trailer and A body???? [Re: max_maniac] #1862814
07/03/15 01:44 PM
07/03/15 01:44 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Lol..... Good, real good
1.41 best 60 foot
6.56 at 104.17
Re: 16 foot open trailer and A body???? [Re: sportfury70] #1862819
07/03/15 01:56 PM
07/03/15 01:56 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I use a 14 w/2 ft dovetail. The dovetail makes for easy access to the back straps.
Yeah, it's got a smallblock.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863334
07/04/15 09:30 AM
07/04/15 09:30 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We've had a 16 ft for over 25 years. Hauled the Road Runner and the Demon on it with no problems.
Nautilus Racing-
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863416
07/04/15 11:42 AM
07/04/15 11:42 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I used it last night. Had about 6 inches room in the front with the back tires just on the flat part of the deck. It was tight.
1.41 best 60 foot
6.56 at 104.17
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863565
07/04/15 02:31 PM
07/04/15 02:31 PM
How did it tow? What are you pulling it with?
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863574
07/04/15 02:46 PM
07/04/15 02:46 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Fine.
2500 crew cab.
1.41 best 60 foot
6.56 at 104.17
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863590
07/04/15 03:11 PM
07/04/15 03:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Your Duster must be a lot longer than my Dart. I have an 18' goose neck, 16' deck and a 2' dove tail. With the back tires about 1' from the break I have 18" or so between the front of the car and the neck.
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863667
07/04/15 04:47 PM
07/04/15 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the problem with the short trailers Don... you dont get
any fore and aft movement to balance the load properly.. if its
to far rearward the trailer will wonder and whip... this is
aggravated even more during braking.. as the nose of the tow ride
dips(normal) the back lifts up and the tongue weight gets even
lighter... this amplifies the whipping condition
wave
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863786
07/04/15 07:28 PM
07/04/15 07:28 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
I am guessing by tight you mean you wanted the rear tires on the flat part of the trailer. You still have four feet to adjust the load if you need.
Actually, you could make it fit in a 12 foot trailer if you had to.
Danny
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1863846
07/04/15 08:33 PM
07/04/15 08:33 PM
Champion City
The Sphinx Offline
The Sphinx  Offline
Champion City
I love my 16 footer. I've hauled A,C,and E bodies on it. Once I put a 67 Caddy sedan de'ville on it
Re: 16 foot open trailer and A body???? [Re: B3422W5] #1864005
07/04/15 11:28 PM
07/04/15 11:28 PM
Is the car centered on the axles? If not you may want to try that to see if it works better or not shruggy My 24 ft.enclose car trailer puts about 800 lbs on the rear end of the truck with the car all the way back so I can barely close the rear ramp door to clear the rear bumper, the motor in the race car is barely in front of the front axle shruggy I had to move it foward to shut the rear ramp door when I put the parachute on the car, that made the back of my 1 ton singe wheel crewcab 4WHD go down some more in the rear, it towed fine though shruggy
