Re: assembly lube [Re: mopar dave] #1861045
07/01/15 04:04 AM
07/01/15 04:04 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Torco
Never had any problem
EVER!
Re: assembly lube [Re: mopar dave] #1861169
07/01/15 12:12 PM
07/01/15 12:12 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i haven't seen any failures using assembly lube. looks like brand doesn't matter. i just bought least expensive stuff i could find. don't think i'll go wrong with joe gibbs.
Re: assembly lube [Re: mopar dave] #1861198
07/01/15 12:55 PM
07/01/15 12:55 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Sealed power- bearing guard. and oil on the rings and pistons
Re: assembly lube [Re: BradH] #1861370
07/01/15 04:41 PM
07/01/15 04:41 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted By BradH
I've used different stuff in the past, but my 452 bottom end went together with:
- Joe Gibbs assembly lube on crank & rod bearings and piston pins
- CMD assembly lube on rod bolts
- Total Seal AL4 piston & ring lube, plus their QuickSeat powder on the cylinder walls
Time will tell...
I used the Total Seal Quick Seat powder on my newest build (540 summer 2014). That had Total Seal AP series rings. That engine seemed to work out just fine. I did think rubbing that powder into the hone marks was odd, but it worked.
Many other builds I used WD-40 on the ring pack and cylinder walls, with a touch of motor oil on the piston skirts, and fine/thick assembly oil (Permatex red) on the piston pins and bearings.
