2004 Grand Cherokee Hot Start and Rough Idle #1847581
06/12/15 07:32 PM
06/12/15 07:32 PM
PA
70Duster Offline OP
70Duster  Offline OP
PA
I have a 2004 Grand Cherokee 4.0L 6 cyl. It has only 33,600 original miles and it is in great condition. I've owned it since new. When re-starting from a hot start, especially in hot weather, it runs rough, almost sounding like a couple of cylinders aren't firing until I give it some gas bringing up the RPM's. Then, it smooths out and runs fine from then on. No codes are set and it runs great otherwise. Any ideas what could be causing this? Anyone have similar issues with their Jeep?
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1848434
06/14/15 12:14 AM
06/14/15 12:14 AM
PA
70Duster Offline OP
70Duster  Offline OP
PA
No one has any ideas?
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1848468
06/14/15 01:01 AM
06/14/15 01:01 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i have a old Dakota with the same problem,in my case its the "new fuel",as it was fine several years ago and nothing i can do will make it go away,you might try premium no ethanol fuel if its available near you,it cant hurt it!
my ladder of success is missing some rungs
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: rhad] #1848568
06/14/15 10:27 AM
06/14/15 10:27 AM
PA
70Duster Offline OP
70Duster  Offline OP
PA
That's interesting. I also have an '87 Dakota with the original carburetor and it runs great even with 10% ethanol. No hot start issues whatsoever.
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1848627
06/14/15 12:22 PM
06/14/15 12:22 PM
scratchnfotraction Offline
my 05 jeep grand Cherokee limited with 4.7 v-8 did the same thing and it was the egr valve needed replaced.
took a while but then it one day popped the code for it.
ran like crap till it popped code then it has ran perfect since it was replaced.
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1858770
06/28/15 11:42 AM
06/28/15 11:42 AM
PA
70Duster Offline OP
70Duster  Offline OP
PA
Just wanted to report back that after a 1000 mile trip, that included a variety of temperatures, mix of highway and backroads, lots of hilly terrain and a fully loaded vehicle, that this issue did not reoccur even once. I'll keep the suggestion of the egr valve in mind if it starts happening again. Thanks for the replies.
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1858914
06/28/15 03:06 PM
06/28/15 03:06 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
A guy at work has a Dakota that was experiencing the hot start/rough idle condition. Ended up being the crank sensor. Seemed odd but it took care of the issue. Evidently the sensor was acting up when hot.
Re: 2004 Grand Cherokee Hot Start and Rough Idle [Re: 70Duster] #1859437
06/29/15 01:45 AM
06/29/15 01:45 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Injectors bleeding off? The coil pack going bad?
