Thermostat issue, falls into housing #1854042
06/21/15 11:43 PM
06/21/15 11:43 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
I ordered a new thermostat for my hemi project. The ousing has casting number 2780987. I ordered a thermostat for 69 440/383 which should have worked for that housing. IIRC, the housing was used from 67 to 70. When I place the thermostat on th ehousing it partially falls in. The thermostat is about 2" in diameter. I recall wider thermostats in last project. A wider one would sit in the recess on the water neck nicely and sit on the housing without falling in. Is this a common issue? I am guessing the thermostat is a generic listed part at NAPA. I wont be able to get there until Tuesday. Is there another part to use? Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854046
06/21/15 11:46 PM
06/21/15 11:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You got the wrong thermostat. What part number did they sell you?
Re: Thermostat issue, falls into housing [Re: NITROUSN] #1854066
06/22/15 12:05 AM
06/22/15 12:05 AM
RapidRobert Online content
RapidRobert  Online Content
iirc my 83 cordoba 318 used the small dia stat with the offset stat housing flange. Yes you need the larger dia one & I think the dimention is greater than 2"
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854072
06/22/15 12:11 AM
06/22/15 12:11 AM
I don't recall part number. I tossed the box last week. I'll have NAPA look it up again, but Ill bring the water next with me. If anyone has a stant part number, that could help.
Thanks.
2023 Ford Mach 1
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854162
06/22/15 04:43 AM
06/22/15 04:43 AM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
Re: Thermostat issue, falls into housing [Re: Sir Valiant] #1854247
06/22/15 11:52 AM
06/22/15 11:52 AM
OT I would get a 180/185 or even a 190, definitely not a 160
Re: Thermostat issue, falls into housing [Re: RapidRobert] #1854284
06/22/15 12:54 PM
06/22/15 12:54 PM
BDW Offline
BDW  Offline
Why?
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854318
06/22/15 01:49 PM
06/22/15 01:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Motor runs more efficiently at the slightly higher temps.
Re: Thermostat issue, falls into housing [Re: BDW] #1854408
06/22/15 04:28 PM
06/22/15 04:28 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Why?
Motor runs better at this temp and the cooling system does not struggle as much to keep your engine cooler than it was designed to operate.. In my opinion 160 t stats are a BAD idea....
Re: Thermostat issue, falls into housing [Re: minivan] #1854480
06/22/15 05:30 PM
06/22/15 05:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How does a cooling system "struggle"?
Re: Thermostat issue, falls into housing [Re: John_Kunkel] #1854560
06/22/15 07:04 PM
06/22/15 07:04 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Because of its childhood...
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854615
06/22/15 07:36 PM
06/22/15 07:36 PM
BDW Offline
BDW  Offline
I don't understand the "struggle" either.
For really cold climates I can understand the need for a higher temp thermostat .
But for cars like mine that will never seen anything lower than 50 deg, I don't see why it's a bad idea to run a 160 thermostat.
The thermostats won't make the car run any cooler, it just starts the process earlier, the natural temp of the engine will be whatever it is. My car always runs around 200-210, and I'd like it to run cooler.
Always looking to learn...........
Re: Thermostat issue, falls into housing [Re: minivan] #1854617
06/22/15 07:37 PM
06/22/15 07:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Years of abuse and neglect...(and use of 160 degree thermostats, flex fans and ??????)
Re: Thermostat issue, falls into housing [Re: RoadRunner] #1854733
06/22/15 09:41 PM
06/22/15 09:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Thermostat also allows the engine to warm up quicker by forcing the coolant inside the engine to recirculate inside the engine.
Don't be the exception.
Re: Thermostat issue, falls into housing [Re: Supercuda] #1854776
06/22/15 10:30 PM
06/22/15 10:30 PM
Yes you wanna get completely out of that "warming up zone" where eng wear is the greatest (by far), as quick as possible.
Re: Thermostat issue, falls into housing [Re: RapidRobert] #1854778
06/22/15 10:42 PM
06/22/15 10:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I thought this was about the thermostat falling into the housing,how soon we stray !! shruggy
Re: Thermostat issue, falls into housing [Re: RapidRobert] #1857514
06/26/15 05:38 PM
06/26/15 05:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree with Robert. I have learn this the hard way more than once. Always thinking the cooler it runs the better, but there's a limit. I have a 160 in my crate engine stroked 360 (410 cubes). I left the old cop radiator in the car and figured I will need the 160. Nope, never really fully warms up and I live in steamy Florida. I am going to swap it out for a 180 or 190.
Facts are stubborn things.
Re: Thermostat issue, falls into housing [Re: RapidRobert] #1858119
06/27/15 01:33 PM
06/27/15 01:33 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
More than once I have read that six pack equipped engines should use a 190 degree thermostat to lessen the chance that raw fuel will 'pool' on the floor of the intake manifold. Uncertain of the validity of the theory, does sound reasonable, likely no downside so I do follow this advice.
Re: Thermostat issue, falls into housing [Re: 62maxwgn] #1858274
06/27/15 05:38 PM
06/27/15 05:38 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Yes it is, but when you see a potential problem with a combination I would appreciate it if someone were to bring it to my attention????
Re: Thermostat issue, falls into housing [Re: minivan] #1858388
06/27/15 09:22 PM
06/27/15 09:22 PM
All interesting reading. NAPA cross referenced the Stant number and I got the right one. 180 deg F. I also made sure to drill 1/8" hole to let air escape as I fill the system.
2023 Ford Mach 1
