Page 2 of 3 1 2 3
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856059
06/24/15 05:59 PM
06/24/15 05:59 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Originally Posted By B3422W5
I pray Quicktree doesn't see this post........ Lol
That's Funny smile
[img] [/img]
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856070
06/24/15 06:17 PM
06/24/15 06:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Appears it broke the rear end, tore cap off. Will know for sure tomorrow 8.75, 489 case, solid spacer.
Funny I didn't hear any noticeable noise pushing it.
I didn't see a thing, but I thought you were one of the guys telling us how great they are? now you have to pull the tranny and check it also. really sorry to hear it though.
Re: Test and tune..... Broke it..... [Re: Quicktree] #1856097
06/24/15 06:50 PM
06/24/15 06:50 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Nope not me. I ran an 8.75 in my old car. Lived a couple years at 11.70's, couple more years running 10.70's, and then when I stepped it up it grenaded and went straight to a Dana and never looked back.
Gonna put it back together and hope this little 318 doesn't bust it again.... Lol
I will feel like an idiot running a Dana with a 318, hope it doesn't come to that.... It's only 475 horse once I get it dialed in..... And I think I have, just need to not break anything now to find out.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856103
06/24/15 07:01 PM
06/24/15 07:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you will be lucky if the tranny case is not destroyed
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856113
06/24/15 07:28 PM
06/24/15 07:28 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Don't think it was, no external damage, and zero leaks.... 904...
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856121
06/24/15 07:41 PM
06/24/15 07:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check it anyway or it could be in your lap
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856123
06/24/15 07:43 PM
06/24/15 07:43 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Will do. It's at a tranny guys shop I know.
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856131
06/24/15 07:59 PM
06/24/15 07:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Trans is probably hurt also, seen it to many times after breaking rear. Please pull trans apart for a look see.
Mopar to the bone!!!
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856133
06/24/15 08:00 PM
06/24/15 08:00 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Talk about guys all posting at once haha.....
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856162
06/24/15 09:05 PM
06/24/15 09:05 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
check the rollers and springs in the sprag
Tony
70 AARCuda Vitamin C
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856233
06/24/15 10:37 PM
06/24/15 10:37 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Dang sounds like my last trip to the track. My car did make one poor pass before my spinning and then hook pass. I thought it was good until I went to launch the car and it went into what felt like a neutral . I found it still pulled a little so I tried to shift to second and it locked up completely. Found the sprag came apart and lock the rear drum. When the rear band applied it locked up. Now waiting on my new super sprag for my 727. Oh by the way mine is a 318 422 cube engine too
6.50 @105.26
Re: Test and tune..... Broke it..... [Re: Kindafast] #1856242
06/24/15 10:53 PM
06/24/15 10:53 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Mine is a 323 cubic inch 318 block magnum motor in my Duster that broke
My old car/ motor was a 422 W5 mill
Just never changed my screen name.... Lol
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: Quicktree] #1856610
06/25/15 01:34 PM
06/25/15 01:34 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Not so fast there Mr. doom and Gloom ... for some odd reason the 904 is not as acceptable to the sprag woes of the 727 , but he needs to look at it anyway ...
Re: Test and tune..... Broke it..... [Re: JohnRR] #1856616
06/25/15 01:40 PM
06/25/15 01:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yea i over looked the 904, thanks for pointing that out Mr. Cheerful laugh2
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856692
06/25/15 03:17 PM
06/25/15 03:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Buddy of mine looking at it just sent me a picture. The axles are stripped.
Looks like only about 1/2 to 3/4 inch of the splines were engaged .
So measuring the rare ds looks like mine is 54 and an A body is 52
Sooo..... I didn't know the rear that was in the car when I bought it was out of a B body
Need to order some B body axles....... I am guessing correct axle spine engagement should be roughly 1.5 inches into the spool on both sides?????????
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856716
06/25/15 03:44 PM
06/25/15 03:44 PM
Kirkland, Washington
Pacnorthcuda Offline
Common problem. The issue is the split gear setup on MOST 8.75s.
Each axle engages a side gear AND a side 'plate' that is part of the clutch assembly of the sure grip. That means of the engagement of the axle-to-side-gear strips out you go nowhere.
Not only are the axle splines trashed, but so are the side gears (at least one) in the diff unit.
A much better design was the one piece where by the side gear and plate are one unit, but they are rare. The side gear and plate are locked together when an axle is installed so they FUNCTION as a single piece, unless, as in your case the small amount of axle spline to side gear engagement strips out.
Re: Test and tune..... Broke it..... [Re: Pacnorthcuda] #1856736
06/25/15 04:06 PM
06/25/15 04:06 PM
CA
crackedback Online content
crackedback  Online Content
CA
From his comments this is not the issue, he has a spool.
Axles too short are the root issue. Sorry to read about this Don. Hope the spool isn't hurt.
Pull it all down, flush out the garbage, measure and start over. Hopefully most all the junk is in the bottom section of your housing. Might be a good time to install a drain plug in the bottom of your housing.
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856916
06/25/15 07:36 PM
06/25/15 07:36 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Bought CORRECT length 35 spine axles and new 35 spline spool to replace the 30 spline stuff I had
Dr Diff is as always a great guy to deal with
Hope to get out soon and give it another try.
Cass said it probably wouldn't have stripped if I had 35 spline to begin with, even with the shallow engagement.
Should have listened to him the first time hammer
1.41 best 60 foot
6.56 at 104.17
Re: Test and tune..... Broke it..... [Re: B3422W5] #1857279
06/26/15 09:55 AM
06/26/15 09:55 AM
an8sec70cuda Offline
Glad it was an easy fix. Check the trans out yet?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Test and tune..... Broke it..... [Re: B3422W5] #1857326
06/26/15 11:37 AM
06/26/15 11:37 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Trying to figure why the Trans needs to come out when the drive shaft never went faster then the rear end it strip a axel not the ring gear when the car stopped so did the driveshaft so why does the Trans need to be checked what am I missing I understand if it dropped the driveshaft or broke ring gear and the driveshaft kept spinning but it did not like I said when the car stopped so did the driveshaft
Page 2 of 3 1 2 3
