Re: dana 60 rear [Re: turbo toad] #1860788
06/30/15 08:12 PM
06/30/15 08:12 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
you can find a 9.25 in a 2.7 ratio---i narrowed one to an A body width to put under my 50 hudson---it is almost as strong as a dana 60...
Re: dana 60 rear [Re: savoy64] #1860830
06/30/15 09:24 PM
06/30/15 09:24 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
iagree
I was wondering when someone would bring that up. A big ring gear for strength, the carrier bearings per-load can be adjusted much easier than a Dana 60, good axles are available and it can be designed to run w/o the C-clips with good brakes. A good option, for sure.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: dana 60 rear [Re: savoy64] #1860839
06/30/15 09:32 PM
06/30/15 09:32 PM
michigan
turbo toad Offline OP
michigan
I haven't thought about A 9.25 i might have to look into it
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: dana 60 rear [Re: turbo toad] #1860892
06/30/15 10:27 PM
06/30/15 10:27 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How about a dana 70, or look into the Jana76, its a real hybrid axle. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: dana 60 rear [Re: astjp2] #1861312
07/01/15 03:29 PM
07/01/15 03:29 PM
dogdays Offline
dogdays  Offline
How is a Dana 70 or Jana 76 going to help someone looking for a 2.73 rear end ratio?
The 9.25 could be a solution but there is no way it'll ever be as strong as a Dana 60. I would really like it to be, but for some reason it isn't. There are plenty of them out there, broken. I think of the 9.25 as in the same strength zone as a GM 12-bolt car rear. My drag racing friend told me he had rebuilt 12-bolts many many times before switching to a Dana 60. After the Dana 60 swap he never touched the rear end, and it was running 4.10 gears from the truck in which it left the factory, plus a spool.
The Ford 8.8 is another possibility.
Taller tires can help.
Rear end life is determined by shock loading and the amount of torque the tires are able to resist.
R.
