Thermostat issue, falls into housing
#1854042
06/21/15 11:43 PM
06/21/15 11:43 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I ordered a new thermostat for my hemi project. The ousing has casting number 2780987. I ordered a thermostat for 69 440/383 which should have worked for that housing. IIRC, the housing was used from 67 to 70. When I place the thermostat on th ehousing it partially falls in. The thermostat is about 2" in diameter. I recall wider thermostats in last project. A wider one would sit in the recess on the water neck nicely and sit on the housing without falling in. Is this a common issue? I am guessing the thermostat is a generic listed part at NAPA. I wont be able to get there until Tuesday. Is there another part to use? Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Thermostat issue, falls into housing
[Re: NITROUSN]
#1854066
06/22/15 12:05 AM
06/22/15 12:05 AM
RapidRobert
iirc my 83 cordoba 318 used the small dia stat with the offset stat housing flange. Yes you need the larger dia one & I think the dimention is greater than 2"
[Re: RoadRunner]
#1854072
06/22/15 12:11 AM
06/22/15 12:11 AM
RoadRunner
I don't recall part number. I tossed the box last week. I'll have NAPA look it up again, but Ill bring the water next with me. If anyone has a stant part number, that could help.
Thanks.
[Re: RoadRunner]
#1854162
06/22/15 04:43 AM
06/22/15 04:43 AM
Posts: 113 PA
Sir Valiant
PA
[Re: Sir Valiant]
#1854247
06/22/15 11:52 AM
06/22/15 11:52 AM
RapidRobert
OT I would get a 180/185 or even a 190, definitely not a 160
[Re: RapidRobert]
#1854284
06/22/15 12:54 PM
06/22/15 12:54 PM
Posts: 4,732 Florida
BDW
OT I would get a 180/185 or even a 190, definitely not a 160 Why?
[Re: BDW]
#1854408
06/22/15 04:28 PM
06/22/15 04:28 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
OT I would get a 180/185 or even a 190, definitely not a 160 Why? Motor runs better at this temp and the cooling system does not struggle as much to keep your engine cooler than it was designed to operate.. In my opinion 160 t stats are a BAD idea....
[Re: minivan]
#1854480
06/22/15 05:30 PM
06/22/15 05:30 PM
Posts: 25,831 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How does a cooling system "struggle"?
[Re: minivan]
#1854617
06/22/15 07:37 PM
06/22/15 07:37 PM
Posts: 10,579 Freeport IL USA
poorboy
Freeport IL USA
Because of its childhood... Years of abuse and neglect...(and use of 160 degree thermostats, flex fans and ??????)
[Re: RoadRunner]
#1854733
06/22/15 09:41 PM
06/22/15 09:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Thermostat also allows the engine to warm up quicker by forcing the coolant inside the engine to recirculate inside the engine.
[Re: Supercuda]
#1854776
06/22/15 10:30 PM
06/22/15 10:30 PM
RapidRobert
Yes you wanna get completely out of that "warming up zone" where eng wear is the greatest (by far), as quick as possible.
[Re: RapidRobert]
#1857514
06/26/15 05:38 PM
06/26/15 05:38 PM
Posts: 15,887 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
OT I would get a 180/185 or even a 190, definitely not a 160 I agree with Robert. I have learn this the hard way more than once. Always thinking the cooler it runs the better, but there's a limit. I have a 160 in my crate engine stroked 360 (410 cubes). I left the old cop radiator in the car and figured I will need the 160. Nope, never really fully warms up and I live in steamy Florida. I am going to swap it out for a 180 or 190.
Facts are stubborn things.
[Re: minivan]
#1858388
06/27/15 09:22 PM
06/27/15 09:22 PM
RoadRunner
I thought this was about the thermostat falling into the housing,how soon we stray !! Yes it is, but when you see a potential problem with a combination I would appreciate it if someone were to bring it to my attention???? All interesting reading. NAPA cross referenced the Stant number and I got the right one. 180 deg F. I also made sure to drill 1/8" hole to let air escape as I fill the system.
