Page 16 of 21 1 2 14 15 16 17 18 20 21
Re: Gen III Hemi, please post things to avoid and know.. [Re: sogtx] #1819756
05/05/15 11:13 PM
05/05/15 11:13 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
Originally Posted By sogtx
What did i do wrong ?
i had the snout on mine machined down 5/8. Others have had the neck cut and rewelded
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1820731
05/07/15 12:27 AM
05/07/15 12:27 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Which holes of the 5.7 crank mains should be plugged, there are 4? Read this back a ways but can't find the post
Re: Gen III Hemi, please post things to avoid and know.. [Re: mcat4321] #1821376
05/07/15 10:56 PM
05/07/15 10:56 PM
upstate western ny
sogtx Online work
sogtx  Online Work
upstate western ny
Thanks for heads up .. I did t want to weld it ...:(
Any pics you can share of your finished mod ?
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1826814
05/14/15 07:40 PM
05/14/15 07:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I know this is about the engines but has anyone tried using the 5 speed automatic in a non computer controlled car. Just looking at it reminds me of a big can of snakes, but it sure would be cool to use.
Re: Gen III Hemi, please post things to avoid and know.. [Re: cudaman1969] #1827886
05/16/15 04:39 PM
05/16/15 04:39 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
The NAG-1 (LX/LC cars) and 545RFE (Trucks) are all computer controlled. I don't know of any stand alone controllers for these transmissions. If you want overdrive, go 727 with a gear vendor or an early 518 without a computer controlled governor. There is little to no support in the aftermarket for these transmissions outside of a stock computer/harness retrofit application that includes the engine control for fuel injection.
Re: Intake gaskets [Re: cudaman1969] #1839689
06/02/15 01:24 PM
06/02/15 01:24 PM
kansas city mo
turbofreek Offline
turbofreek  Offline
kansas city mo
Pre 09 5.7 blocks can go 4 inches in bore but its best to have it sonic checked to be for sure. Will require a custom piston at this time till others start really doing it. Andy at pwr has one running for a few years now on his own vehicle i was told by him. Cylinders are still thicker than the 6.1 as well.
Again sonic testing the walls is best when taking that much material out.
Im doing a 4" 5.7 05 block with eagle heads an 80mm billet turbo.
dont feel like typing it again
Re: Intake gaskets [Re: gregsdart] #1848101
06/13/15 02:45 PM
06/13/15 02:45 PM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
what is the max lift for stock rocker arms
Re: Intake gaskets [Re: gregsdart] #1850262
06/16/15 07:55 AM
06/16/15 07:55 AM
gregsdart Offline OP
Guys say .650 is it,,,,
Re: Intake gaskets [Re: gregsdart] #1850484
06/16/15 02:27 PM
06/16/15 02:27 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Yes, .650" is pushing it. I'm living it right now.....
Re: Intake gaskets [Re: gregsdart] #1852416
06/19/15 10:21 AM
06/19/15 10:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can I'd like to see this thread broke down into
different parts so its a bit easier to get the info... as
in
Blocks.. which ones are best for what reason
Cranks... what will interchange and the stroke of each
and if there is any diameter changes
Cams... max lift, duration and so on
you get the idea... I've been searching on here for different
info but its sorta hard to find and I dont want to ask if its
already out there
wave
Re: Intake gaskets [Re: MR_P_BODY] #1852500
06/19/15 01:59 PM
06/19/15 01:59 PM
Chicago, Illinois
donscuda Offline
donscuda  Offline
Chicago, Illinois
I agree with you. thumbs Larry is close to having my 5.7 ready and put it in my Cuda, and I'm still having some questions and having this broken down would make it easier to find some answers without using the search tool...
With as popular as this engine is becoming with all of the new car sales, and the swaps that are going on. Maybe we should have a 3rd Gen Hemi Section in the main forum, and break that up into the different sections. That way we could have a section for the street guys too.
Re: Intake gaskets [Re: gregsdart] #1852601
06/19/15 04:12 PM
06/19/15 04:12 PM
maine
LO23 Offline
LO23  Offline
maine
check out G3 HEMI SWAP on facebook.
Re: Intake gaskets [Re: donscuda] #1852722
06/19/15 07:20 PM
06/19/15 07:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would like to see a Gen3 section also
wave
Re: Intake gaskets [Re: gregsdart] #1852758
06/19/15 08:00 PM
06/19/15 08:00 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a ton of swap info I could contribute.
Mopar to the bone!!!
Re: Intake gaskets [Re: gregsdart] #1852777
06/19/15 08:35 PM
06/19/15 08:35 PM
USA
hudsonhornet7x Offline
USA
Yes please on the Gen III section. Organization would be awesome! I would contribute what I have discovered as well.
Re: Intake gaskets [Re: gregsdart] #1853144
06/20/15 12:43 PM
06/20/15 12:43 PM
Chicago, Illinois
donscuda Offline
donscuda  Offline
Chicago, Illinois
I would add anything I could too. I already found out that I ordered the wrong ignition harness for my FAST fuel injection system. I ordered the 5.7, but because of the way the motor is set up, I needed the 6.1 harness.
And I 'd like to add, the reason I only had one mistake so far is the fact that I have such an experienced person like Larry Griffith doing the work. I was just going to go with another small block until talking with Larry.
Re: Intake gaskets [Re: MR_P_BODY] #1854206
06/22/15 10:32 AM
06/22/15 10:32 AM
wave
Having started this thread, I heartily agree it is time to gather all the info and add it to some other much more easy to research form or section. I think the original thread should stay for the purpose of info gathering, but a tech article or section editable by MODs only would be a great way to do it.
Re: Intake gaskets [Re: gregsdart] #1854659
06/22/15 08:19 PM
06/22/15 08:19 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Definitely time for a GenIII section. Information is extremely scattered and plenty of it is being kept as tribal knowledge. This whole thread could -easily- be broken down into sub-threads of "power steering", "fuel system", "ECU/Control Units", "Oiling and Exhaust", "intakes", "heads", etc for in-dept discussion of each area.
If nothing else, I wonder if there is some sort of free Wiki-Page we can setup for members to create their own tech articles and people can add to it, reference other pages, etc. Those are exceptional online databases that are easy to create and search.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Intake gaskets [Re: GoodysGotaCuda] #1855032
06/23/15 10:06 AM
06/23/15 10:06 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I agree this IS the future for us.
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1858825
06/28/15 12:55 PM
06/28/15 12:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Two questions, any problems putting the 6.1-6.4 crank in a 5.7 block,maybe cam line up? Next, how or what is used to mate the 904-727 trans to the 5.7? 5.7 is an 2007.
