64 Belvedere Door Issue #1849913
06/15/15 09:01 PM
06/15/15 09:01 PM
64MAX Offline OP
64MAX  Offline OP
I have a 64 Belvedere wagon and the front passenger side door is stuck shut. I've managed to get the interior panel off but can't figure out what's happening. It seems to be unlocked - I can move the linkage up and down. The inside handle moves the linkage to the latch as it should but it won't budge. Does any one have any ideas or do I need to remove the fender and get it off that way. Thanks for any help I can get.
Re: 64 Belvedere Door Issue [Re: 64MAX] #1849957
06/15/15 09:30 PM
06/15/15 09:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try opening the door from the outside and lifting up on it at the same time.
Re: 64 Belvedere Door Issue [Re: stumpy] #1850102
06/15/15 11:40 PM
06/15/15 11:40 PM
64MAX Offline OP
64MAX  Offline OP
It doesn't budge at all. It's stuck very solidly. Thanks.
Re: 64 Belvedere Door Issue [Re: 64MAX] #1850306
06/16/15 10:06 AM
06/16/15 10:06 AM
Minn
SportF Offline
SportF  Offline
Minn
Does it wiggle in an out a little, or just doesn't move at all? If it doesn't move at all, try pushing in and moving a handle to the open position at the same time. As suggested, it may be necessary to push in and up at the same time as well.
The door latch (the part that is on the body) may have moved and needs re-adjusting, which sounds simple, but can be a real pain to get it right.
If it wiggles, the body latch may be real loose and is moving with the door latch and won't dis-engage. If that is the case, you need to get something inside the post to momentarily hold the body latch stationary. Good luck with this, it can be some frustrating trouble.
Re: 64 Belvedere Door Issue [Re: SportF] #1850349
06/16/15 11:26 AM
06/16/15 11:26 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I did Auto glass in the late 70's for a living...
When a Door glass broke ( tempered glass) it broke into a million pieces and I had times where a piece of that glass got into the latching mechanism ( the door jamb mechanism, NOT the handle part) and made it inoperable..
Understand here, I had to get the door open to install the new door glass..
By inoperable I mean everything worked fine, door button pushed in, all of the linkages moved, but the latch would not release...
Try looking around the latch/jamb mechanism inside the door for something causing this.. Use a screwdriver or cotter key remover ( Hook tool) and poke around to clean anything stuck or jambed into the latch...
It will be frustrating, don't give up.....
Re: 64 Belvedere Door Issue [Re: 64MAX] #1850524
06/16/15 03:14 PM
06/16/15 03:14 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
The little "star" in the door part is frozen, squirt rust buster, inside the door, back of latch, pry with crowbar to get it moving, worked for me.
Re: 64 Belvedere Door Issue [Re: 64MAX] #1850543
06/16/15 03:52 PM
06/16/15 03:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Removing the fender and unbolting the hinges is a waste of time , the latch will still be stuck.
Re: 64 Belvedere Door Issue [Re: JohnRR] #1850577
06/16/15 05:11 PM
06/16/15 05:11 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I just had this happen last week. RH rear door on a 64 Fury stuck closed. With lock button up (unlocked position), and a helper holding the door handle button in, I got in back seat and layed down and pushed with my feet on the door. Kinda light kick, without removing anything. Lubed and adjusted once open.
Re: 64 Belvedere Door Issue [Re: Bull1tt] #1850599
06/16/15 06:02 PM
06/16/15 06:02 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Originally Posted By Bull1tt
Kinda light kick,
That's what I've always done in the past...I just didn't want to get flamed for it... panic
...FAFO...
Re: 64 Belvedere Door Issue [Re: Bull1tt] #1850662
06/16/15 08:47 PM
06/16/15 08:47 PM
fredericksburg,va
fredericksburg,va
That's what I meant just didn't say it right.
Re: 64 Belvedere Door Issue [Re: cudaman1969] #1850995
06/17/15 11:50 AM
06/17/15 11:50 AM
64MAX Offline OP
64MAX  Offline OP
Thanks for all of the ideas guys. I'll give them a try when I have a chance. The gentle kick might be the best bet. There is no wiggle in it at all. It's almost like it's welded. Tugging on the outside handle only raises/moves the whole car. I'll let you know if I get it loose.
Re: 64 Belvedere Door Issue [Re: cudaman1969] #1851656
06/18/15 09:22 AM
06/18/15 09:22 AM
64MAX Offline OP
64MAX  Offline OP
Thanks to all! The "light kick", or maybe a not so light one, did the trick. It's now open, lubed and working fine. Many thanks.
