My Cuda Rear Leaf Springs are Rattling my Teeth Out!!
#1827050
05/15/15 01:49 AM
05/15/15 01:49 AM
Posts: 113 PA
Sir Valiant
PA
I'm guessing that my car has SS springs as it rides like an empty dump truck as stated in other posts and rides real high, especially with the new 17"'ers. I want to put other springs on but the springs have been moved in and the shocks are straight up and down. Can I just put stock plus 1"'s on, are they the same length? These are the best pics I have for now. The front hanger has 2 holes and it's already in the upper hole. Thanks!! http://mopar1.us/cuda/rear1.jpghttp://mopar1.us/cuda/rear2.jpg
Re: My Cuda Rear Leaf Springs are Rattling my Teeth Out!!
[Re: Sir Valiant]
#1827189
05/15/15 12:14 PM
05/15/15 12:14 PM
RapidRobert
I would assume going back to regular springs would soften it and I would assume that all A body springs are the same end to end but iirc some (SS) the center pin is slightly forward or back from normal which is gonna locate the axle & actually the shock being vertical is giving you the most dampenening. OE +1" get recommended alot. I bought a 65 dart roller with 003/003 SS springs & they needed shock extensions but when done it rode high and tight/real nice.
[Re: Sir Valiant]
#1829505
05/18/15 09:16 PM
05/18/15 09:16 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
The angle of the rear shocks are adding to the stiffness in the ride.
The further you lay a shock down, the less effective it will be. Straight up is the exact opposite.
Go after that problem before you swap springs.
[Re: ahy]
#1849211
06/15/15 12:02 AM
06/15/15 12:02 AM
Posts: 22,696 Bitopia
jcc
Bitopia
"They just like just standard KYB's." Bingo
[Re: Sir Valiant]
#1849771
06/15/15 06:17 PM
06/15/15 06:17 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If the car was set up to use real SS springs and someone installed B/E body SS springs they would be too long. Stuffing them in the car would raise the rear end (as yours is) and they would be bent over too far to compress over bumps. It would ride incredibly stiff.
I learned that the hard way when I put the 69 B-body springs on the 65. The 65 main leaf is shorter. The springs were nearly inflexible.
[Re: jcc]
#1849819
06/15/15 07:36 PM
06/15/15 07:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
"They just like just standard KYB's." Bingo Yeah, that's the problem, not. If your teeth are rattling it's isn;t the KYB's, unless they are seized or something like that.
[Re: Sir Valiant]
#1850208
06/16/15 02:30 AM
06/16/15 02:30 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I had the same problem for years. I tried mono leafs and Caltracs, but they were brutal too.
I consulted with Dr Diff, and he solved the problem of the buckboard ride. He told me to use two passenger side Super Stock springs, but this time for a 1968 a-body. They are the 2800lbs springs.
It worked. My car rides better than it ever has, sits perfect and hooks up hard.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: feets]
#1850432
06/16/15 01:37 PM
06/16/15 01:37 PM
Posts: 5,161 CT
GTX MATT
CT
I learned that the hard way when I put the 69 B-body springs on the 65. The 65 main leaf is shorter. The springs were nearly inflexible. This would be true. If the car sits up like that on the upper hole I think something is off. I bet you have B body S/S springs (454/455 or 456/457) in there instead of E body.
[Re: Sir Valiant]
#1850471
06/16/15 02:15 PM
06/16/15 02:15 PM
jcc
Bitopia
I'll disconnect the shocks and see if the ride is better but it still sits too high so these springs are coming out. That would be interesting, but not really informative. I suspect based on a number variables, it could possibly improve, I think your time would be better spent borrowing any other shock, to test and see if there is an improvement's at no cost. My guess is the shock is only part of the problem ( I never stated otherwise), and the low hanging fruit here, and KYB's have this reputation pf harshness (although Not all users concur), and I have had the same experience. Your spring package is the next change to consider. FWIW, I use composite springs, and will likely never consider anything else on my cars.
[Re: AARCONV]
#1850851
06/17/15 12:54 AM
06/17/15 12:54 AM
Posts: 113 PA
Sir Valiant
PA
