Modern dual plane W/W2 heads? #1848593
06/14/15 11:42 AM
06/14/15 11:42 AM
northeast ohio
mkdart Offline OP
mkdart  Offline OP
northeast ohio
I have an old set of W2 race heads,that I'd
like to use on my rig.
Here is the combo.
A body 3600 w/me in it.
360 &.040,4 inch crank (BPE).
Mildly ported factory iron heads.
245/251 solid cam,253/255 solid on shelf.
RPM intake/750 DP.
9.5 comp./tti 1 5/8-1/3/4 step headers.
2 1/2 system to bumper W/X pipe.
TKO-600 5speed (.64 5th).
3.91,w/a set of 4.30's on the shelf.
28 inch tire.
The car is 95% street,driving in city traffic.
Doesn't get above 4500/5000 very often,plus
I have overdrive.
I've heard the horror stores about the tremic
transmission's so I try to keep the shift
point's to 6000.
Can't help but think a modern dual plane reworked
may be better for me than the M1 I have.
I've seen a couple of stories that guys have used
LA intakes and reworked them for W2 use, thoughts?
Thanks Mike
Re: Modern dual plane W/W2 heads? [Re: mkdart] #1848682
06/14/15 01:28 PM
06/14/15 01:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I cant say for the smallblock but use the Indy dual plane on my 63 thats a 440/493 and its a 99% street car that usually sees the track once or twice a year. But it gets a ton of street miles and I can say I really like how good the low end driveabilty is with the dual plane. And I must say I dont see many bigblock strokers around 490 to 500 cubes using a dual plane. But as for street driveabilty its great. up I do want to try a single plane one day just to see if its faster at the track. Ron
Re: Modern dual plane W/W2 heads? [Re: mkdart] #1848802
06/14/15 03:18 PM
06/14/15 03:18 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a brand new Mopar Performance W2 dual plane intake I would sell if you are interested.
