flow kooler watr pumps worth it? #1749852
02/09/15 01:40 AM
02/09/15 01:40 AM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
this water pump being considered for a 360 being built for a Ramcharger
I see on Summit website that this pump is listed along with a Summit brand and a milodon high volume for this application. The Flowkooler is a few $$ more but with the $10 "summit bucks" that comes with this one (but not the house branded one or the Milodon) once that is spent the price is within a few $ of each other;
They show the impeller on the site on the Flowkooler but not on the other 2 in the "detais" section of the respective "info" page. that makes them hard to compare.
The FK is anodized, sure makes it "look nice" but like chrome valve covers looks don't mean anything, if they don't improve performance.
Anyone run the Flowkooler? I have one coming at the moment but still not installed so I can return it if I need to. apparently a "brand new' not Reman"
All the moron on the phone at Summit could tell me about each was that they were all made in the USA which is very important to me!
Re: flow kooler watr pumps worth it? [Re: volaredon] #1749853
02/09/15 08:43 AM
02/09/15 08:43 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
The flow cooler that I had had a disc behind the impeller the milodon I also had did not.
Re: flow kooler watr pumps worth it? [Re: Scamp408] #1749854
02/09/15 09:39 PM
02/09/15 09:39 PM
ILLINOIS
V
V
ILLINOIS
yeah; I know the Flowkooler does have that, while they fail to show the business end of the Milodon to see just what that one does have.
Some on the newer cars have a disc on them (not necessarily talking Mopars with that statement) but wouldn't that in turnm hinder flow instead of help it?
One thing I know is that I won't ever put a 6 blade one on again, I did that on my bone stock 78 Fury's 318 and immediately noticed that it rruns warmer than it did with the original 8 vane pump because that was what the parts store had in stock... I mat well order one of these Flowkooler pumps for that car and re replace it..
Thinking for future needs/ does Flowkooler offer a rebuild service or at least a rebuild kit for their pumps?
Does Milodon actually make them? or does someone else where they just put their name on them? The flokooler appears to be a brand new pump/casting and all, where the Milodon and the Summit look like they "could be" reman's.
Re: flow kooler watr pumps worth it? [Re: volaredon] #1749855
02/10/15 12:22 AM
02/10/15 12:22 AM
so ca
mikesiron Offline
mikesiron  Offline
so ca
I use the enclosed impeller in our circle track engines with NO restrictions and a few other cooling mods. We can run with the front air intake blocked off (dirt car)never had any issues with heating. The hottest it gets is 210 on a very hot summer day and 30 lap mains. The one's without the enclosed impeller don't work no were as good.
Re: flow kooler watr pumps worth it? [Re: volaredon] #1749856
02/10/15 12:31 PM
02/10/15 12:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a Flow Kooler pump on my 408. I bought it to use on the 340 that I built for the car almost 10 years ago. I was trying to run an electric fan and was having overheating issues with a brand new copper radiator, so I put an aluminum radiator and a different electric fan on it, still hot. Changed to the Flow Kooler pump still hot. Installed a viscous fan and made a shroud to fit, no more overheating problems.
When I built my 408 I used the Flow Kooler pump and the same fan set up off the 340. On the hottest days it runs around 180* with a 160* thermostat. My understanding is that the plate helps with cavitation, you can do the same thing by welding an aluminum plate to the timing chain cover. Just make sure you have clearance for the impeller.
The Flow Kooler pump starts with a new housing and IIRC it has bigger bearings too.
Re: flow kooler watr pumps worth it? [Re: justinp61] #1749857
02/10/15 01:32 PM
02/10/15 01:32 PM
dogdays Offline
dogdays  Offline
Yeah, it's the plate that makes the Flowkooler work better. It makes the impeller more efficient.
The guys who designed the pumps knew that, but cost wins over something that the average car buyer is never likely to notice.
I used to specify pumps and there's a really simple answer but I can't remember it at the moment.
I'd say that few of the hot rod parts "manufacturers" actually have a shop or factory somewhere turning out parts, the same way that most of the components in an automobile were actually made by smaller companies that specialize in supplying the automobile industry.
So the question about Milodon making their own pumps is misleading. They most likely have the pumps made to their specifications. Just because a company is churning out stock style parts, it does not follow that the parts they made for Milodon or Moroso or whoever is exactly the same part.
Long time ago I had a professor who had started his career with Whirlpool. They also made appliancxes for Sears and Montgomery Ward. His experience was that the name brand appliances were made up to a standard, while the appliances they made for the store brands were made down to a price. The big stores would go out for bid and low bidder got it. So the quality went down.
R.
PS: In the circle track world Howard Stewart is the name for water pumps.
Re: flow kooler watr pumps worth it? [Re: dogdays] #1749858
02/10/15 10:15 PM
02/10/15 10:15 PM
ILLINOIS
V
V
ILLINOIS
R.
never heard of Hoard Stewart, myself but the engine that I am wanting to put this water pump onto is a '76 360 being built for a Ramcharger
3 season daily driver that will occasionally tow a boat and a camper (not at the same time)
Said engine will have a Carter TQ, magnum heads, Eddy Performer intake, Speed pro flat top hypereutectic pistons, and a Comp 260H cam.
Re: flow kooler watr pumps worth it? [Re: volaredon] #1749859
02/10/15 11:01 PM
02/10/15 11:01 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I got one. It replaced the OE 8 blade one that blew up on me driving home from the track last fall. It's an OE replacement housing with their impeller thing and bearings. It works, kept the temps in my 340 down pretty well, almost too low! I turned 7K with it, no issues.
I got a Griffin rad, OE shroud, clutch fan and a 160 t-stat. I'm also running serp belt pulleys which are under driven a little which can be dicey in a street car but it was fine. Have not had it long enough to report on driving it in super hot weather. Will be going on the 416 I am building.
Might be worth putting in your Ram. Just seems to help the cooling system work to it's full potential.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: flow kooler watr pumps worth it? [Re: RMCHRGR] #1749860
02/10/15 11:19 PM
02/10/15 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like a nice impeller except for the 3/16"-1/4"
of the shaft sticking past the impeller blade.. if
they hold the impeller off the back wall that amount
it just looses flow... if that shaft lines up with
the mounting edge of the housing then it might have
looses.. other than that I like the impeller with
the spill plate on the back and the blade count
Edelbrock's version [Re: MR_P_BODY] #1749861
02/11/15 12:44 AM
02/11/15 12:44 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
FWIW here's a picture of Edelbrock's version which has a solid back impeller. Can't comment on heat, my car's cooling was adequate with a stock 6 blade impeller. I bought it because I liked the idea of no cavitation at high rpm and also the local parts stores were only getting junk rebuilds from Cardone.
Not a Chrysler casting. It comes with brass NPT to hose fittings. I bought the stainless ones seperately. The casting has a small interference issue on the inlet. I e-mailed Eddy but never got a follow up after sending the pics.
Re: Edelbrock's version [Re: Mattax] #1749862
02/11/15 12:51 AM
02/11/15 12:51 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Arrow points where some filing was required.
This is on a '68 340 block with a later style timing cover (marks cast in) and obviously using the later style water pump.
Re: flow kooler watr pumps worth it? [Re: volaredon] #1749863
02/11/15 12:38 PM
02/11/15 12:38 PM
an8sec70cuda Offline
I put a Flow Kooler pump on one of my old street/strip 440s a long time ago. Dropped the temp about 10°.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: flow kooler watr pumps worth it? [Re: volaredon] #1848297
06/13/15 09:24 PM
06/13/15 09:24 PM
ILLINOIS
V
V
ILLINOIS
ok I have to dig up an old thread of mine.
Different application but same question. My son and I have not yet had time to finish that 360 destined for his Ramcharger so I never got to see how well that pump worked,
BUUUUT now this is on my 78 Sport Fury, 318, so "stock" it still has its Lean Burn... only mods are true duals (2-1/4 diam from manifolds to bumper) and cat converter delete. 2.Xx rear gear, factory AC, mechanical fan (no clutch, that's how this car came originally) original radiator that has been checked out buy local rad shop and claimed to be "fine". I am 2nd owner (have had since 2007) car has 51K original miles.
Problem; car runs HOT at highway speeds. Did not peg the needle but after a 30 mile run at 75-80 MPH, it held "3/4 gauge" for the last 5-6 miles, a few minutes after shutting off I did hear antifreeze gurgling back into the bottle. Never did that when I got the car, I ran Power tour in '09 and '10.
Somewhere along the line I replaced the WP with a new one. Removed 8 vane, parts store claimed that 6 vane was all that was available. Ever since, it has run war5mer than previously, even in town, where it hangs at 1/2 gauge or just above. The longer I'm on the highway the higher the gauge climbs.
I am definitely going to re-replace that water pump, I need to get rid of the 6 vane, would a Flow Kooler be worth it over a factory style 8 vane pump?(new if available or else an 8 vane reman)
Re: flow kooler watr pumps worth it? [Re: volaredon] #1848347
06/13/15 10:19 PM
06/13/15 10:19 PM
Jamie McGrath Offline
Maybe you have a hose collapsing when the rubber hose gets hot under load?
Re: flow kooler watr pumps worth it? [Re: volaredon] #1848348
06/13/15 10:25 PM
06/13/15 10:25 PM
usa
smos001 Offline
smos001  Offline
usa
I have 383 built with a hydraulic roller, 10.3 to 1 KBs, 750 DP, Harlan sharp rockers, 26 rad,shroud,160 t-stat and a flow kooler water pump.
Most of the time I run around 165-170 on the coolant temp. Yesterday it was mid 90s outside. It never went over 180.
The pump looks well built and my engine builder was impressed when I brought it to him complete the build.
I would say it's worth the money.
Coolant temperature is dependent on many variables; timing,air fuel mixture , air flow, etc.
I wanted to reduce at least one variable. So I bought the flow kooler. Seems to be well engineered.
Re: flow kooler watr pumps worth it? [Re: volaredon] #1848471
06/14/15 01:07 AM
06/14/15 01:07 AM
ILLINOIS
V
V
ILLINOIS
well I am gonna "borrow" the Flow Kooler pump that my son bought for his Ramcharger for my Fury and order him another.
I took it out of the box so I could paint it, and saw something disheartening/disappointing. It has "GMB" cast into the housing and stamped on the nose of the shaft. GMB is a cheaper-end brand of auto parts, that i have had mixed luck with in the past. so whoever said they don't make their own got it right.... though the last GMB that I wound up with went on the 318 in the 83 D 250 that I used to have and it didn't have the plate on the back side of the impeller like this "Flowkooler" one does.
I just primered it with Dupli color gray "engine primer" tomorrow morning it will get the "318 Blue" sprayed onto it, then onto my Fury.
I think the fact that I dropped from an original 8 vane pump on that engine to a 6 vane is the majority of the problem with it.... that's where I'm starting with it to try and solve this anyway and go from there.
Re: flow kooler watr pumps worth it? [Re: Mattax] #2015690
02/19/16 09:48 PM
02/19/16 09:48 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Could you tell me where to get the stainless or brass hose nipples?
Re: flow kooler watr pumps worth it? [Re: boydsdodge] #2015808
02/20/16 01:07 AM
02/20/16 01:07 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think the factory ones were just zinc coated steel and not stainless. Most Mopar restoration places sell them. If you want them in stainless or brass find a local plumbing supply store. Probably cheaper to boot.
Click "cooling system" and then go under heater hose nipples to find stock ones.
https://www.hooverautoparts.com/index.php?cruising=products&category=Cooling System
Re: flow kooler watr pumps worth it? [Re: volaredon] #2015820
02/20/16 01:26 AM
02/20/16 01:26 AM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
440 source BB water pump has a similar in design impeller at a lower price.I do not know if it cools better but maybe someone on board can give some first hand info on these pumps.
Re: flow kooler watr pumps worth it? [Re: hankcrank] #2015866
02/20/16 02:30 AM
02/20/16 02:30 AM
I'd get a parts house 8 blade pump & weld an anticav plate on it of the thickness needed to get ~.020" clearance to the t cover "flat" for a more efficient pump (keep in mind gasket thickness) but you were good with the prior 8 blader WO the cav plate. tho that symptom (hiway overheating somewhat especially at a steady speed) is more likely from a partly plugged radiator. any possibility the duals have leaned the lean burn a bit too much? and making it run hotter. I just measured my 8 blade pump today & I'm gonna cut a circular disc tomorrow, either 4 or 6" (left the sheet in the garage) & first press the vanes in so you have ~.020 on the back side (actually in front when it is installed on eng) & drill a hole in the center to weld there to the shaft/center of vanes & cut the OD just smaller than the vanes so you can weld several of the vane tips to the plate. Did anything else precede the overheating other than the pump (8 to 6 vane) change?? Something don't feel right
