Re: 2nd place in class at BBORR - video
[Re: slantvaliant]
#1815261
04/30/15 11:06 AM
04/30/15 11:06 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Thanks Lyndal! Great video, great pics as well!
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1845472
06/10/15 12:20 AM
06/10/15 12:20 AM
Posts: 7,548 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
What a fascinating video, I watched the whole thing. Man, would it be a learning experience to watch this along with running commentary from you as you recall what you were thinking when driving it.
Most curious to understand why the throttle is on the low side from the 21:00 to 22:00 and 24:00 marks - seems there is opportunity to open up more… but what do I know. I can hear your copilot talking, is he telling you what to expect? And most G-forces you hit are .4 and .5 then that big jump to .7 close to the end made my heart jump.. very exciting to watch. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: Uhcoog1]
#1845493
06/10/15 12:57 AM
06/10/15 12:57 AM
Uhcoog1
Houston Tx
Art-
We were trying to dial-in on our 'target time'. We were ahead of pace by 30+ seconds at one point, so we slowed down. Then we were behind so I had to push it a bit!
glad you enjoyed the video. It was fun running it, that's for sure.
My navigator - my brother - was mostly telling me what speeds to take the turns. We wrote down target speeds from watching our previous year's video right before. Excited to have better data for next year!
[Re: Uhcoog1]
#1845523
06/10/15 01:38 AM
06/10/15 01:38 AM
Posts: 23,295 Here
jcc
Here
On this thread, I haven't heard any mention of a radiator shroud, is there one? That's usually the solution du jour here on cooling issues.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: Uhcoog1]
#1845531
06/10/15 02:05 AM
06/10/15 02:05 AM
Uhcoog1
Houston Tx
jcc: No shroud in front. Only a Taurus fan behind. And the radiator is sealed to the sheet metal.
[Re: Uhcoog1]
#1845654
06/10/15 11:56 AM
06/10/15 11:56 AM
Posts: 23,295 Here
jcc
Here
The reason I ask is, conventional wisdom has been anything in the path that aids low speed air flow cooling, inhibits high speed air flow, including any fan. It would seem like your cooling issues are in "inhibiting" range. I understand car needs dual range cooling. I would have thought your what looks to be very functional spoiler/splitter would be a bigger plus in cooling then you have shared here. I personally don't think its related to air not being able to escape after exiting radiator, more not enough air getting in. You do have a lot of items in front of the hot water. Guess we can wait and see how you resolve this.
[Re: dd340]
#1846533
06/11/15 12:01 PM
06/11/15 12:01 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I do the same type of racing at Silver State Classic. My 496 stroker would never go below 65 psi (above 2500 rpm) on the hottest days even with 220° water temps, but during Silver State, by 15 minutes in it would settle in at 38 psi at 4900 rpm. It really bothered me and I blame my eventual Crane Gold rocker arm failure on that pressure issue. Ultimately, I ditched the unbushed Crane Gold aluminum rockers for bushed chromoly Comp Ultra Magnum rockers and went to Brad Penn 20W-50. Last run I did not go below 60 psi.
That oil, when really cold (under 45°), will be slow to come up to pressure.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Uhcoog1]
#1846542
06/11/15 12:22 PM
06/11/15 12:22 PM
67Charger
Erda, UT
Does the radiator have bypass flaps to allow high speed air a route through when it overwhelms the fan? I don't even run a shroud, just a mechanical 17" fan 1/2" off the radiator. Radiator is a Howe Racing 19x27" dual 1.125" core aluminum crossflow generic. The car stays cooler with the air dam since it keeps pressure down under the hood. Your scoop is doing the opposite and offsetting the gains from the dam. Raising the rear of the hood is iffy if it is too close to the high pressure zone at the base of the windshield. Think about the NASCAR guys using the windshield base cowl induction for power gains. Same high pressure as a scoop without the drag.
Heat extractors, louvers, etc. may help tremendously in creating a lower pressure underneath the hood and really improve air flow through the radiator. It worked wonders on my dad's Firebird running 150+ MPH and keeping under 200°.
[Re: Uhcoog1]
#1846544
06/11/15 12:27 PM
06/11/15 12:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The old 10 psi per 1000 rpm guide is sadly out of date.
[Re: 67Charger]
#1847030
06/11/15 11:31 PM
06/11/15 11:31 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
this is pretty cool, I did not know this, I thought it was more for aerodynamics to have the flat hood in nascar with the windshield base cowl
[Re: Uhcoog1]
#1847204
06/12/15 09:19 AM
06/12/15 09:19 AM
Uhcoog1
Houston Tx
Honestly I would like more oil pressure. This motor has been that way since day 1. I'll probably pull the oil pump and port the inlet- some folks I've spoken with think I've got a cavitation issue, as the pressure drops after 4800-5000 rpm. It's lived through a couple hard track days and BBORR, so I can't really say the oil pressure is a problem.
Supercuda- you say the 10 psi per 1,000 rpm is outdated- is there another rule of thumb to consider? Or anything else to add to this? I agree with you, but sure would like more info on the subject to give me more peace of mind!
The current plan for the radiator is to seal the front crossmember to the hood, seal the hood to the body (specifically in the back at the high pressure cowl area), and seal the scoop to intake so that pressure doesn't bleed off into the rest of the engine bay (though I doubt the scoop builds much pressure). Lastly I'd like to build some ducting on the front side of the radiator to direct and stack air going into the radiator, and block off the grille where no airflow is needed.
I do not have flaps on the fan shroud. I ran closed road course sessions back to back with and without the fan. Zero temp difference. Average speed of around 78-80 mph though.
[Re: Uhcoog1]
#1847350
06/12/15 01:44 PM
06/12/15 01:44 PM
Uhcoog1
Houston Tx
I actually have one. Bought it years ago after reading the autospeed articles about hood venting, etc.
Time to pull it out!
[Re: dangina]
#1847425
06/12/15 03:34 PM
06/12/15 03:34 PM
Posts: 28,096 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
this is pretty cool, I did not know this, I thought it was more for aerodynamics to have the flat hood in nascar with the windshield base cowl The NASCAR cowl intake system serves two purposes. It gets a little higher pressure air into the engine (poor boy supercharging) and it relieves the pressure at the base of the windshield. Very few high speed cars have conventional hood scoops outside the drag racing community.
[Re: Uhcoog1]
#1849490
06/15/15 12:00 PM
06/15/15 12:00 PM
67SATisfaction
Albany, NY
Art-
My navigator - my brother - was mostly telling me what speeds to take the turns. We wrote down target speeds from watching our previous year's video right before. Excited to have better data for next year! OK, got it. Thanks. That adds another dimension to the run, so you have to drive very deliberately, which shows in the video. Smart. Like "match racing" at the dragstrip (which at our strip means you declare your 1/4mi time before the run, and you have to beat your opponent without dipping below your declared time. The Christmas tree lights launch you sequentially such that each competitor would theoretically arrive at the finish line according to their declared times). Does it mean next year you'll use a 'target time' that's 30sec less than this year, depending on conditions? Best of luck! - Art
[Re: Uhcoog1]
#1849702
06/15/15 04:05 PM
06/15/15 04:05 PM
67Charger
Erda, UT
Specific speed targets over a calibrated distance. Think INDEX racing, with your over or under being you "variance". Silver State is 90.000 miles long. 180 class (index) guys all try to finish in EXACTLY 30 minutes. 135 class guys finish in 40, 120 class guys finish in 45, etc.
[Re: Mr.Yuck]
#1849792
06/15/15 06:58 PM
06/15/15 06:58 PM
feets
Senior Management
Senior Management
Irving, TX
Lifting the back of the hood will hurt air flow under the hood. The base of the windshield is a very high pressure area at 130+ mph. It will flood more air under the hood.
Closing off the hood scoop or ducting it to the throttle bodies would help alleviate some of the problem.
