Re: The new M/T radial slick. [Re: racerx] #1847673
06/12/15 09:14 PM
06/12/15 09:14 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Gotcha.............Thaxs up
Re: The new M/T radial slick. [Re: grncpe] #1847687
06/12/15 09:36 PM
06/12/15 09:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By grncpe
Racerx, forgot to mention cal trac mono leaf with bars, cal trac shocks with the Hemi .
Santhuff shocks with the 383
Hey Ron , it weighed 3195 without me and a alum headed Hemi .
383 ss motor was 3050 without me. All off the nose of the car. Of coarse I had to add some weight to it as I have to weigh 3470 for ss/ja. I have been running it at 3560 ish so I will lighten it up a little also to get it a little closer to min weight. That is with me in the car.
Thanks Tom. If you dont mind me asking do you know the HP that 383 makes. I dont know anything about your 383 but thats a strong 60 so it sure sounds like a strong 383 stocker eng. How fast has it gone with that stout 383 ? Thanks , Ron
Re: The new M/T radial slick. [Re: 383man] #1847712
06/12/15 10:17 PM
06/12/15 10:17 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Ron, it is factory rated at 300hp, 😊 I have been 10.15 @129.98 in testing
Same set up at maple grove for div 1 points meet went 10.19 @ 129.xx
This is in bracket mode with 3 year old tires & 100 lbs heavy so it is pretty stout for a 383
I am in super stock not stock eliminator, the motor in the car was built by Steve Wann.
I will keep you posted on how things progress.so far in qualifying I have been .809 under the index in bracket mode, hoping to go .900 or better but the air is going in the tank for the summer.
Re: The new M/T radial slick. [Re: grncpe] #1847829
06/13/15 12:40 AM
06/13/15 12:40 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I was on Mickey Thompson's web sight and they have 2 different NEW tires I am interested in. The ET Drag Radial 29.5/10.5 with the R1 compound and the Pro Bracket Radial 29.5/10.5 with X5 compound. All the specs are the same except the compound and the ET Drag Radial is 2 lbs lighter. I am running the 315/60 ET Street Radial now that is the same height but 1 in wider. I would think the first 2 would be the best of both words since they do not have any tread and are a radial but they are 1 in narrower.
Which one of the 2 new ones work the best?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: The new M/T radial slick. [Re: D-50] #1847928
06/13/15 09:25 AM
06/13/15 09:25 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
D-50,
You may want to try asking Jason Moulton , from MT , over on Yellowbullet . He was helpful to me , though i have gone back to Hoosier radials . I have tried the lightweight Hoosier 9x30 , 29.9 dia . Was very happy but did not have enough gear . I am only a small radial guy , Hoosier 275 , with not enough power .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
