Re: Yep.. Just Another Day at my House
[Re: RodStRace]
#1847530
06/12/15 06:13 PM
06/12/15 06:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wow! I've never seen or heard of that either, so you are exploring new territory here. Glad to hear you are okay. Have you thought of Dzuz clips for the nose? It would have still bent stuff, but it wouldn't have to come up so high to clear. With 15 trips in and out already, I'd try to make it as quick and painless as possible. I've pulled that engine/trans out of it at least 10 times.. with the same set up... I have no plans on using dzus fasteners... it normally clears the front end and the hood.... it was just my piss poor luck
[Re: MR_P_BODY]
#1847662
06/12/15 09:00 PM
06/12/15 09:00 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[quote= I just need to see what I want to do for a cherry picker Keep the cherry picker you have. Get a new ram and reengineer the mounting points a little. The current set up looks like the lift beam Starts out waay to low. By the time the beam gets to a decent height the rams arm is already extended pretty far. Shorten that aspect of it, and add a closer ram push mount point on the lift beam. Your more then capable and enjoy that type stuff.
[Re: Quicktree]
#1848031
06/13/15 01:02 PM
06/13/15 01:02 PM
MR_P_BODY
I'm thinking about picking up another lift.. on mine the front wheels are splayed out like a V and its the width of the front tires so I have to pull the fronts to clear.. I'd like to get one that the frame is a H type so the front wheels would clear
[Re: Quicktree]
#1848044
06/13/15 01:25 PM
06/13/15 01:25 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
the design of the lift looks flawed to me. thats why i wanted to see the whole thing. look at Monte's his pushes straight up. Mike's base is set further back and pushes out and up, not a good thing imo. Mine appears to have the same size ram as Mr Ps.....but I have picked up things WAY heavier than a small block/tranny combo. I think his ram is simply in the wrong place.......easy fix. Mine is 30 years old and we have split tractors with mine. I would imagine the ram is set back on his to help get closer to stuff without hitting the ram on the front.......but again, easy fix. Extendable boom. When I have to do that, I just put a few 100lb tractor weights on the rear of mine MrP........I also have a lift like you say with splayed legs. I simply cut notches in the legs, pulled them together with a ratchet strap, welded them back up. From what I see, your lift looks really heavy duty, just bad ram placement
[Re: MR_P_BODY]
#1848051
06/13/15 01:32 PM
06/13/15 01:32 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Sorry to see Murphy came to visit. His law sucks
But thanks for the reminder that things we have done many times can go wrong
"Just a Bracket car dressed up like a streetcar"
