2011 Ram rear lowering kit #1844969
06/09/15 03:00 PM
06/09/15 03:00 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
Has any one used 2009-2015 Dodge Ram 1500 4wd Rear 2" Drop Coil Springs - McGaughys 44055 if so how did you like it.
thanks nick
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1849365
06/15/15 03:15 AM
06/15/15 03:15 AM
Colorado
GPSflyer Offline
GPSflyer  Offline
Colorado
I didn't order springs, but I cut two loops off my rear springs last year.
It leveled the truck out, and rides great.
Took about 20 minutes.
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1850387
06/16/15 12:16 PM
06/16/15 12:16 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
Thanks GP, that looks great, I ordered McGuaghys spring 3 days ago along with a power tailgate lock. I'll see how that goes. thanks again.
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1855073
06/23/15 11:23 AM
06/23/15 11:23 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Might have to put those springs on my newly purchased 14. I wonder if I could get it done without the wife noticing?
There is an aftermarket air bag system installed inside the stock springs. I wonder if I'd be able to retain those bags with the new springs?
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1856028
06/24/15 04:59 PM
06/24/15 04:59 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
I just ordered ( http://www.sdtrucksprings.com/air-lift-60818-air-spring-kit-dodge-ram-1500-09-14? ) for the truck today. I also hocked up a $35 backup camera that works great so far and a power tailgate that also works great. I hocked that up to p door pop (the second pop on the key fob )
When i put the air lift on i will add cables to the shocks so the spring don't came out when you jack it up. So far the ride is the same as be for.
If l never told my wife what i was doing she probably would of never noted.
good luck
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1856558
06/25/15 12:55 PM
06/25/15 12:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Post pictures of the shock cables when you get it done. It looks like I have the same air bag system as your link. The bags look the same. You have to keep a minimum of 5psi in the bags at all times to prevent bag failure. I don't think pumping them up to 35psi(max psi rating)will actually "lift" the back end. I think it just swells the bag into the space between the coils. At least that's what I assumed when I read the instruction online.
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1858079
06/27/15 12:21 PM
06/27/15 12:21 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
Air bags should be here tuesday, when i get them in and hock the cables up i'll take some pics and post them.
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1866211
07/07/15 10:58 PM
07/07/15 10:58 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
I didn't need cables with the McGuaghys spring, the springs were long enough. You might need them if you cut the stock springs?
For driving around not towing i'm at 5psi, i had it at 15psi it was a little bouncy.
I just put the air bags in today so i'm still playing with them.
The best way to put the bags in is to take the springs out and that big rubber insulster on the top of the spring, put the air lift black puck into the rubber, (i don't think you will ever get that puck in that rubber insulster with the spring in.)
Re: 2011 Ram rear lowering kit [Re: 37dodge] #1866273
07/08/15 12:31 AM
07/08/15 12:31 AM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
heres a pic. (this is a test for posting pics. will it work?)
