1972 or 1973 Imperial Tire Info Sticker #1840234
06/03/15 02:03 AM
06/03/15 02:03 AM
West Central Wisconsin
DeMopuar Offline OP
DeMopuar  Offline OP
Does anyone have access to a 1972 or 1973 Imperial (doesn't matter two or four door) with the original tire information sticker still mounted on the car? My coupe has been repainted, and while the VIN door sticker is still there, it only has the GVWR, date when assembled, and the VIN. There is no specific size of tire or psi air tire pressure information present here. Is there a separate informational sticker for this on a fuselage C body? I'm not even certain it would be found in the door jamb area or not? It might even be in the engine bay somewhere? I just don't know, this is the first Imperial I have owned.
At any rate, if anyone out there can help out with a description of where it would be mounted and a clear photo of what the entire sticker looks like that would be great.
Thanks,
Mark
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: DeMopuar] #1840303
06/03/15 07:51 AM
06/03/15 07:51 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Inside the trunk lid I think. Door jamb didn't become normal till the 80's.
Angry white pureblood male
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: DeMopuar] #1840311
06/03/15 08:30 AM
06/03/15 08:30 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
You might try searching over at the Imperial website. http://www.imperialclub.com/
Ron
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: DeMopuar] #1840722
06/03/15 07:17 PM
06/03/15 07:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I can take a look when I get home, assuming I remember.
- Stu Harmon
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: feets] #1841055
06/04/15 12:26 AM
06/04/15 12:26 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Here is the sticker on my 72 Imperial. It is on the B pillar about 1/4" below the door striker.
- Stu Harmon
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: feets] #1841639
06/04/15 07:44 PM
06/04/15 07:44 PM
DeMopuar Offline OP
DeMopuar  Offline OP
Awesome feets -- that's the best..............
Could I ask for one more favor -- can you get a nice close up of the numbers at the bottom of the label, the last two numbers that I can easily see are 94.
Thank you!!!!!
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: DeMopuar] #1841682
06/04/15 08:38 PM
06/04/15 08:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
340bleh094
biggrin
I think "bleh" is a 2 but it's hard to tell. I'll have to double check tonight.
Have you found a source for L84-15 tires yet? laugh
- Stu Harmon
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: feets] #1841806
06/04/15 11:37 PM
06/04/15 11:37 PM
DeMopuar Offline OP
DeMopuar  Offline OP
Hey, whenever you can get to it is fine by me -- I'm just glad someone is willing to help -- you know how it is................
Even if they were available I wouldn't be using those. I've got big plans for my 73 coupe. Hopefully I can get buried in this car financial wise so I have to keep it forever -- I guess that's my stupid plan.................... These are great cars, so I really don't care I guess.
Thanks again feets!!!!!!!!!
Mark
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: DeMopuar] #1842015
06/05/15 11:22 AM
06/05/15 11:22 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Glad to see someone taking an interest in the cars.
The number is 3402094.
- Stu Harmon
Re: 1972 or 1973 Imperial Tire Info Sticker [Re: feets] #1842019
06/05/15 11:38 AM
06/05/15 11:38 AM
DeMopuar Offline OP
DeMopuar  Offline OP
Thank you very much...............
