Re: K frame dolly
[Re: ScottSmith_Harms]
#2201518
11/23/16 11:41 PM
11/23/16 11:41 PM
Posts: 2,105 New Mexico
JMCFAN
New Mexico
I vend the US Cartools engine dolly and lift system, and I use them too ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Super high quality and safe. Made installing the drive train in my Duster a breeze. they are available for all Mopar engines. Agree Scott.. great purchase... engine went in like a breeze! I know I could have fabed one out of furniture dolly's and lumber... but too much invested for me..
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: K frame dolly
[Re: Challenger 1]
#2201521
11/23/16 11:48 PM
11/23/16 11:48 PM
JMCFAN
New Mexico
The problem I see is...you guys are lifting the car and drive train with a engine crane and not a car crane. Talk about having a lot invested. That crane ain't made to hold the whole car and drive train after you bolt it in. It is very dangerous at that point. NO... lift is used to lower the car onto the drive train...and then your done...I never lifted the car after the K member bolts were fastened...
Re: K frame dolly
[Re: 469runner]
#2201929
11/24/16 05:03 PM
11/24/16 05:03 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
When the body is lifted it weighs so little a couple of strong guys could raise it. Yes, I could grab the body and lift it myself...In this last case it was a convertible but I've done it with hardtops also... I use one of the lifts for the ease of install... I made up a heavier version of the T framing type and have made up optional accessories for other year installs...
Re: K frame dolly
[Re: MoparJunkie]
#2202122
11/24/16 11:47 PM
11/24/16 11:47 PM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
All this talk of cost,I was given all the metal and huge casters for free so I literally have the cost of the gas and wire for my welder in this project.
On the ground my small cheaply jack fits under it,the car is on jack stands so I jacked the dolly up in to place,now I will remove the k-frame bolts and lower the whole assembly to the ground,then lift the front of the car and roll everything out from under.
Oh yeah,I spent $7 on a tap.
who is that guy?
Re: K frame dolly
[Re: MoparJunkie]
#2202216
11/25/16 03:58 AM
11/25/16 03:58 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Here is the one I made (actually I made 2) it also doubles as a run/break in stand
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: K frame dolly
[Re: MoparJunkie]
#2202631
11/25/16 10:43 PM
11/25/16 10:43 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
LOVE the dual purpose dolly / run stand. Was going to help a friend build a run stand I we were thinking of making it a dolly too. Yours give me some great ideas. Thanks for sharing!!!!!!
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: K frame dolly
[Re: Cuda Cody]
#2202975
11/26/16 08:29 PM
11/26/16 08:29 PM
AZ_A12_BEE
Dreaming of the 808
LOVE the dual purpose dolly / run stand. Was going to help a friend build a run stand I we were thinking of making it a dolly too. Yours give me some great ideas. Thanks for sharing!!!!!! The run in yoke is designed to hold a 26 in radiator and use the same hoses as a 68-69 B body, and it slides out if you only need the dolly
37 Plymouth PU
Re: K frame dolly
[Re: AZ_A12_BEE]
#2202979
11/26/16 08:32 PM
11/26/16 08:32 PM
AZ_A12_BEE
Dreaming of the 808
Another pic without a K member on it
37 Plymouth PU
Re: K frame dolly
[Re: AZ_A12_BEE]
#2202981
11/26/16 08:35 PM
11/26/16 08:35 PM
AZ_A12_BEE
Dreaming of the 808
Run/break in yoke by itself
37 Plymouth PU
Re: K frame dolly
[Re: MoparJunkie]
#2203020
11/26/16 09:55 PM
11/26/16 09:55 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
How do you put the bolts in from k-frame to frame? From the picture the k sets on those studs to line it up, are they removable?
Re: K frame dolly
[Re: cudaman1969]
#2203080
11/27/16 12:07 AM
11/27/16 12:07 AM
AZ_A12_BEE
Dreaming of the 808
How do you put the bolts in from k-frame to frame? From the picture the k sets on those studs to line it up, are they removable? It's not designed for install into a car, that requires transfer to cart made for install, those carts tend to be a lot higher off the ground
37 Plymouth PU
Re: K frame dolly
[Re: MoparJunkie]
#2203418
11/27/16 06:08 PM
11/27/16 06:08 PM
Brian_wo
Omaha Nebraska
After seeing the new posts here I had to build yet another piece.
The dolly works perfect and with the large casters it rolls around with little effort.
who is that guy?
