Re: does it matter what side of ballast resistor?
[Re: copperSwinger]
#1840057
06/02/15 10:16 PM
06/02/15 10:16 PM
RapidRobert
With MSD you bypass the ballast so the small red wire gets fire in "crank" and in "start" which means the coil will get full voltage. this is good if you are using a MSD compatible coil designed for this. this is as far as my MSD knowledge goes and with the fast rise time of the MSD system a regular coil not designed for full 12V may or may not be OK with full voltage/no ballast & not sure if the small red wire needs full 12V which if so means you could not power it thru the ballast. here's a BTT for ya & wait for someone who knows MSD to chime in
[Re: copperSwinger]
#1840312
06/03/15 08:35 AM
06/03/15 08:35 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I just installed an MSD, and connected both the run and start leads to the small red wire so it would fire during cranking and run. Works fine. I looked at the instructions, and basically they want you to hook to a 12+ switched wire, so it turns on and shuts off the ignition system. I assume all there is is an internal relay which then supplys the juice to the ignition components. If you can find a switched 12+ that is still hot during cranking, fine. Call MSD tech and ask about using both start and run wires, just to make sure. I was willing to chance it, but don't want to advise you to unless they give the green light. I don't see a problem, but you just never know.
[Re: copperSwinger]
#1840323
06/03/15 09:15 AM
06/03/15 09:15 AM
Posts: 1,756 London, England
Gavin
London, England
Discussed much through the years.....definitive answer is you don't HAVE to use the ballast with an MSD6A, but you CAN if you want to. All that signal is providing is effectively a logic level - 6V, 12V, it doesn't care, the coil supply is not routed from there.
Those who leave out the ballast do so because it is one less failure point, they don't have a ballast, or just don't want it there. Those who leave it in do so because it is an easy source of a start/run signal, and/or they want to leave the ballast in so they can revert to a stock system easily if required (eg if the MSD fails)
Choose your preference, but the MSD does not care. (yes, this is verified by MSD themselves)
[Re: Gavin]
#1840529
06/03/15 02:54 PM
06/03/15 02:54 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's true that the MSD signal voltage isn't important but how can you run the ballast and still have a signal signal in both Start and Run?
[Re: gregsdart]
#1841068
06/04/15 12:34 AM
06/04/15 12:34 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I just installed an MSD, and connected both the run and start leads to the small red wire so it would fire during cranking and run. Works fine. I looked at the instructions, and basically they want you to hook to a 12+ switched wire, so it turns on and shuts off the ignition system. I assume all there is is an internal relay which then supplys the juice to the ignition components. If you can find a switched 12+ that is still hot during cranking, fine. Call MSD tech and ask about using both start and run wires, just to make sure. I was willing to chance it, but don't want to advise you to unless they give the green light. I don't see a problem, but you just never know. Thats right as you dont need the ballast with MSD so you just take it out. You do need a 12 volt key on (ign 1) and the 12 volts while cranking (ign 2). If you dont hook the ign 2 circuit up it wont start while cranking until you let go of the key. And since ign 1 and ign 2 are seperate circuits on the ign switch you wont have any backfeed from the ign 1 the 12 volts at key on so it wont crank when the key is turned to the run posistion. Ron
[Re: copperSwinger]
#1841208
06/04/15 08:57 AM
06/04/15 08:57 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I joined the blue and brown wires out of the bulkhead and took to the MSD. Easy peasy
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: John_Kunkel]
#1841212
06/04/15 09:05 AM
06/04/15 09:05 AM
Gavin
London, England
By using the factory wiring - it supplies voltage to the coil during crank AND run, if you use that as your input to the MSD (small red) that's all you need. IMO, another advantage of keeping ballast - no recreating a supply that the factory already has...
[Re: Gavin]
#1841393
06/04/15 01:36 PM
06/04/15 01:36 PM
RapidRobert
As covered just connect the two circuits at the ign sw or bulkhead or bypass ballast or hide wire in or behind ballast. The other unaswered Q (to me) is can you run a "regular" (non MSD type) coil with full voltage (bypassed) ballast in ign1 (run) & I ain't talking about an E coil (which iirc you can with that type) but a regular coil like if you were doing a conversion. So if you convert to MSD do you need a MSD coil or an E coil to avoid burning the coil out?
[Re: Lefty]
#1841672
06/04/15 08:21 PM
06/04/15 08:21 PM
RapidRobert
"So if you convert to MSD do you need a MSD coil or an E coil to avoid burning the coil out?"
Depends on the coil resistance. Most of the breakerless ignitions call for a specific coil resistance or narrow range of resistances to work with their box. Alright, got it, thank you!
