Just move the throttle cable... Cheap and easy.
Just what Dizuster said.
I just started index racing in footbrake only classes. I'm racing with a lot of guys that have it down to a science (mostly by adding weights) and they are real good at it. I started by trying to adjust my shift points and actually did fairly well but not good enough against the hardcore index guys. At my last race the car ran two identical numbers during test & tune but it was running too slow. Then I realized I had been working on the top of my motor and when I reassembled it I forgot to adjust the throttle linkage. I adjusted the linkage correctly but after the race was over it hit me, adjust the throttle linkage to the index.
With the set up I was running I ran 6 identical ETs
that day 10.006... ET based on the closest to 10.000 set your
line up position ... I ended up 2nd that day... I ended
up red lighting after the 5th round
