Need Convertor Help!! #1840697
06/03/15 06:36 PM
06/03/15 06:36 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Hey guys my A12 is about ready for its trans. Dudek built the engine with a Mr. Six Pack cam and stock manifolds on it and I talked to Dave about a convertor and he said use a Turbo Action 17501 but they are ALL sold out and have been back ordered for months with none in sight.
That is what I would like to run but without one available I called Bob since he made the cam and he is a great guy to talk to and he said get a convertor as close to a stock 383 convertor as the cam likes a tight convertor. He said it does not have to be a big fancy convertor as loose is not good for this cam. Anyone know what the stall on a stock 383 convertor is? And who stocks a comparable convertor?? Thanks for any help
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Need Convertor Help!! [Re: vette1986] #1840951
06/03/15 10:56 PM
06/03/15 10:56 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
You can buy a converter across the counter but there are a lot of torque converter manufacturers that will make one for your car. They will need a lot of information (Motor size, cam specs, rear end ratio, car weight, car use, tire size and more). Even if you want an across the counter converter, it's always good to give them a call. Like everyone else, I have my favorite companies. My last converter was from Perfect Converter of Cleveland and I couldn't be more pleased. Great customer service too. I'm sure others will chime in with their choices and maybe some companies to steer clear of also.
Re: Need Convertor Help!! [Re: vette1986] #1841004
06/03/15 11:44 PM
06/03/15 11:44 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Re: Need Convertor Help!! [Re: pattyboy 572] #1841070
06/04/15 12:35 AM
06/04/15 12:35 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted By pattyboy 572
No. The description says 360 balance.
