BB Mech Roller Lifter which one? #184071
01/04/09 07:56 PM
01/04/09 07:56 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
Ahhh the never ending saga continues!! Looks like I need a set of roller lifters the old set fit a little loose and upon manipulaion light shown though so I guess I need a new set to take care of the oiling issue. Which brand is the best bang for the buck without breaking the bank or my back?
Diego
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184072
01/04/09 08:00 PM
01/04/09 08:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ISKY solid bodys..........been beating em street/strip for almost 4 yrs. The part # is 1612-RH.......ask for Rod.
Re: BB Mech Roller Lifter which one? [Re: Thumperdart] #184073
01/04/09 08:02 PM
01/04/09 08:02 PM
I like Lunati race series..Priced reasonable as well...
Re: BB Mech Roller Lifter which one? #184074
01/04/09 08:12 PM
01/04/09 08:12 PM
Diego-Town, CA
Diego-Town, CA
PapaJ are these the ones you are talking about?
Product Line: Lunati Vertical Bar Roller Lifters
Part Type: Lifters
Part Number: LUN-72420LUN
Lifter Style: Mechanical roller
Lifter Link Bars Included: Yes
Link Bar: Vertical
Lifter Outside Diameter (in): 0.904 in.
Lifter Offset: None
Quantity: Sold as a set of 16.
Lifters, Mechanical Roller, Vertical Link Bar, Chrysler/Dodge/Plymouth, Set of 16
Thx Ted
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184075
01/04/09 09:00 PM
01/04/09 09:00 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Just curious. Anything wrong with Crane solid roller lifters??
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184076
01/04/09 09:04 PM
01/04/09 09:04 PM
Go get a Crower and take a good, hard look at theres I like and use there extreme duty ones BTW, a little loose is way better than a tiny bit to tight on them just like pistons, bearings, valve guides and so on
Re: BB Mech Roller Lifter which one? [Re: Cab_Burge] #184077
01/04/09 09:11 PM
01/04/09 09:11 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
For me, and for the money a Crane Ultra Pro can't be beat. Crane has standard, pro, and ultra pro lifters. I would only use the ultra pros with a big spring. Ultra pros sell for around 550-600 a set.
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184078
01/04/09 09:41 PM
01/04/09 09:41 PM
Part Type: Lifters
Link Bar: Vertical
Lifter Offset: None
Thx Ted
That's the one Ted...I like them because they are made in pairs, they don't have a loose steel bar that you have to put together which has a lot of play in it..I have never had a lifter problem/failure with them..I have seem many problems with the Comp and Crane lifters..As Cab said he Crower extreme are good to..But for the price I feel the Lunati has the best by far..I run them in all my motors and use them in all customer motors unless they want something else..
Hope you build is going well... jim
Re: BB Mech Roller Lifter which one? [Re: dthemi] #184079
01/04/09 09:43 PM
01/04/09 09:43 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
is this a solid body you can use on a stock unbushed block
1.39 9.85 - 137 mph
Re: BB Mech Roller Lifter which one? [Re: Ari440] #184080
01/04/09 10:44 PM
01/04/09 10:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have had no problems with the plain old comp stuff, no doubt the lifters previously named are better, but you did say budget..I have run the comps for years, and so has many of my friends....You don't hear about failures to often..When you do they had other problems, or been in the engine for thousands of runs...
You can easily get 3-4 seasons out of a set, depending on the runs. 600 passes no sweat.
Re: BB Mech Roller Lifter which one? [Re: Bob_Coomer] #184081
01/04/09 11:14 PM
01/04/09 11:14 PM
Diego-Town, CA
Diego-Town, CA
Thanks everyone, I guess I will have to take a hard long look at the lunati, cause with the Summit discount I can get a set for around $260 and with all the cash I have going out these days that is something I cannot ignore??
Ted
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184082
01/05/09 12:09 AM
01/05/09 12:09 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
all solid rollers will need to rebuilt, and i have heard that comp has the best deal on rebuilding there own.
Re: BB Mech Roller Lifter which one? [Re: 70blackfish] #184083
01/05/09 01:13 AM
01/05/09 01:13 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just for what it's worth I thought I'd say why I like the ultra pro cranes so much. It's just our experience with Fords that led me to my opinion.
Standard dia ford tappets are almost identical to Chrysler manufacturer to manufacturer. The big difference is a Ford tappet is the smallest dia of the bunch. We do a bunch of big Fords every year that use a standard dia tappet with cams and springs that should have a .937 or at least a .903, or a .904. A fair number of customers don't want to spend a penny more than they need to just get by, and that's fine, it is what it is. Some of these cams are 1.100 or more lift with evil pressure, and fast ramps. The only tappet that we've found that will live ANY time at all under this strain (FOR THIS AMOUNT OF MONEY) is an ultra pro from crane. Comp,isky,lunati,crower,ect,ect, usually die on the dyno (AT FACTORY FORD DIA.) So what this meant to me was when a factory dia Ford tappet from Crane would live where others would not, surely their Chrysler and Chevy dia lifters would be the toughest of the bunch since they're just fatter than the Ford tappet. The larger dia Chrysler tappets from all those guys seem to work fine, I'm just convinced from what I described that if a Crane ultra pro can live in a Ford being that small, and unsupported as they are, then surely a big fat Chrysler dia one would be tough as nails.
Re: BB Mech Roller Lifter which one? #184084
01/05/09 09:20 AM
01/05/09 09:20 AM
Diego-Town, CA
Diego-Town, CA
Poppa J what kind of builds are you talking street, stip High HP ect.
thx
Diego
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184085
01/05/09 09:57 AM
01/05/09 09:57 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
How do those Lunati lifters work in an unbushed block?
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184086
01/05/09 10:27 AM
01/05/09 10:27 AM
thx
Diego
Ted,
I mainly build Superstock motors and Q-16 bracket motors..Most all are over .725 on cam lift up to over .800.. I use the same lifters in both wedge and hemi motors.. Most of the time the block is not bushed...All roller lifters need replaced at some point..The Lunati lifter have always been super reliable and a great price..With the cost of parts these days they are a real bargain...Some lifters are almost three times as much.. poppaj
Re: BB Mech Roller Lifter which one? [Re: 70blackfish] #184087
01/05/09 11:10 AM
01/05/09 11:10 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Just wondering if anyone has had them rebuilt lately? How many $$
Re: BB Mech Roller Lifter which one? [Re: mac56] #184088
01/05/09 11:17 AM
01/05/09 11:17 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Comp Cam Lifter Rebuild - all w/ .800 diameter wheel
part number 800-RB2-1
http://www.compperformancegroupstores.co...;Category_Code=
$12.13
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: BB Mech Roller Lifter which one? [Re: RylisPro] #184089
01/05/09 04:05 PM
01/05/09 04:05 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
It cost $185.00 to have Comp cams rebuild mine a few weeks ago. $567.00 for Jesel to rebuild the rockers but they had to replace 7 rollers.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: BB Mech Roller Lifter which one? [Re: Diego_Ted] #184090
01/05/09 06:23 PM
01/05/09 06:23 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
The best bang for the buck without breaking the bank lifters would be Herbert HERTDV lifters for $219.99
