You can buy a converter across the counter but there are a lot of torque converter manufacturers that will make one for your car. They will need a lot of information (Motor size, cam specs, rear end ratio, car weight, car use, tire size and more). Even if you want an across the counter converter, it's always good to give them a call. Like everyone else, I have my favorite companies. My last converter was from Perfect Converter of Cleveland and I couldn't be more pleased. Great customer service too. I'm sure others will chime in with their choices and maybe some companies to steer clear of also.
