Check out the numbers on this 499 mill?
#1840592
06/03/15 03:58 PM
06/03/15 03:58 PM
Posts: 2,070 CA
crackedback
CA
Jan-Mar 2015 Engine Professional Magazine. 400 based 499 MP 509 cam, 248/248 @ .050 114 LSA OOTB RPM heads MP stroker windage tray 7 qt Moroso oil pan Wieand G-Force single plane 10.3:1 Crane 1.5:1 aluminum roller rockers Meziere Electric water pump MSD crank trigger and distributor Holley Terminator EFI 642 LB-FT @ 4,900 RPM and 657 HP @ 5,800 With a 509 Hyd camshaft and OOTB Ede RPM heads... Hmmm... Something seems strange and it was dyno'd at Koffels. http://engineprofessional.com/epQ115.html
Re: Check out the numbers on this 499 mill?
[Re: crackedback]
#1840603
06/03/15 04:09 PM
06/03/15 04:09 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I saw that buildup too. Not the first time I've seen an engine make BIG numbers (too big) on Koffel's dyno.
[Re: crackedback]
#1840681
06/03/15 05:55 PM
06/03/15 05:55 PM
Posts: 43,116 Bend,OR USA
Cab_Burge
Jan-Mar 2015 Engine Professional Magazine. 400 based 499 MP 509 cam, 248/248 @ .050 114 LSA OOTB RPM heads MP stroker windage tray 7 qt Moroso oil pan Wieand G-Force single plane 10.3:1 Crane 1.5:1 aluminum roller rockers Meziere Electric water pump MSD crank trigger and distributor Holley Terminator EFI 642 LB-FT @ 4,900 RPM and 657 HP @ 5,800 With a 509 Hyd camshaft and OOTB Ede RPM heads... Hmmm... Something seems strange and it was dyno'd at Koffels. http://engineprofessional.com/epQ115.html I learned a long time ago that some, maybe most magaizine writers tend to embellish results for more impresive and shock value, maybe like fishermen and golfers are known to do I've had freind and fellow racers that had street and stip cars that where featured in magazines years ago, the drag test where done at the old LACR track near Palmdale ,CA in the Mojave high desert, the actual ET and MPH where adjusted(and maybe embellished some ) for track elevation and weather conditions according to the magazine writers when questioned about the actaul time slips for the car that day compared to what was written in the articles Believe nothing you read or hear about cars in magazines or anywhere else on TV or the net you don't see the actual results yourself
