Who's flat solid cam? SB #1839423
06/02/15 01:02 AM
06/02/15 01:02 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I'm need a flat solid cam for my 340, the hydraulic in it now is bad. This is the motor I built for my Dart in 03 and replaced it with a 408 in 09. I bagged the short block and put it on a shelf.
Over the winter I pulled the 408 to freshen it and found some odd cam and main bearing wear and the flat solid cam was on it's way out. I bought a 395" R1, Indy head motor, sold the rotating assembly and am gathering parts for a 434" build.
So..........I thought I'd bring the 340 out of moth balls, put the heads and intake back on, check the bearings and run the pi$$ out of it until I have the new motor built. Wrong! While looking it over today before mounting it on the engine stand I noticed some pitting on the nose of one of the lobes. After closer inspection there is another lobe showing the same, so this cam was on it's way out too. Both cams were from the same company and had been ran for about five years.
I need another cam. Who do you guys recommend?
Re: Who's flat solid cam? SB [Re: justinp61] #1839502
06/02/15 03:37 AM
06/02/15 03:37 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo.
Re: Who's flat solid cam? SB [Re: justinp61] #1839512
06/02/15 04:09 AM
06/02/15 04:09 AM
W. Kentucky
W. Kentucky
Dan this a pump gas deal, 11.2-1 with ported Edelbrocks and either a Victor 340 or a Weiand X-cellerator, 1 7/8" Hedmans, 3260# Dart.
Re: Who's flat solid cam? SB [Re: justinp61] #1839549
06/02/15 09:20 AM
06/02/15 09:20 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have always called Dwayne Porter, and had him spec and order a cam for me. He is the man
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Who's flat solid cam? SB [Re: justinp61] #1839622
06/02/15 12:07 PM
06/02/15 12:07 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Bullet Cams
Re: Who's flat solid cam? SB [Re: justinp61] #1839630
06/02/15 12:15 PM
06/02/15 12:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years.
Fastest 300
Re: Who's flat solid cam? SB [Re: justinp61] #1839656
06/02/15 12:36 PM
06/02/15 12:36 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would also inquire about EDM or Grooved lifters
Re: Who's flat solid cam? SB [Re: B3422W5] #1839658
06/02/15 12:39 PM
06/02/15 12:39 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Who's flat solid cam? SB [Re: justinp61] #1839662
06/02/15 12:53 PM
06/02/15 12:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I had an old erson cam in a 340 once that worked real good. it was a 12:1 340 though and pulled hard right thru 7000rpm.
258/258@50-.535/.535 on a 107. 340 had ported J heads. my car was a 4 speed then with a 4.56 gear. that was a solid flat tappet. hope this helps
Re: Who's flat solid cam? SB [Re: an8sec70cuda] #1839670
06/02/15 01:02 PM
06/02/15 01:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
iagree
I've also had very good results w/ the cam Dwayne spec'd & supplied.
Re: Who's flat solid cam? SB [Re: qwkmopardan] #1839677
06/02/15 01:10 PM
06/02/15 01:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Totally agree with this.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who's flat solid cam? SB [Re: Crizila] #1839740
06/02/15 02:26 PM
06/02/15 02:26 PM
W. Kentucky
W. Kentucky
I haven't miced the cam. The 340 cam has two lobes that have pitting on the nose of the cam. one of the lobes shows wear all the way across the lobe with pits that will catch you fingernail. The bottom of that lifter looks to have been hit with a tiny needle scaler. The other lobe is just starting to pit. The rest of the lifters and lobes look perfect.
The 408 had EDM lifters in it and has several lobes and lifters as I described above.
Re: Who's flat solid cam? SB [Re: justinp61] #1839810
06/02/15 03:51 PM
06/02/15 03:51 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
What company? Was it a big cam? What oil were you using?
Re: Who's flat solid cam? SB [Re: justinp61] #1839830
06/02/15 04:20 PM
06/02/15 04:20 PM
W. Kentucky
W. Kentucky
The hydraulic was around 240 @ .050, .590 lift the solid was 260 @ .050, .630 lift. The oil was Rotella diesel with a zinc additive. No point in naming the cam company and starting a Moparts witch hunt.
Re: Who's flat solid cam? SB [Re: MIKES_DUSTER] #1839841
06/02/15 04:32 PM
06/02/15 04:32 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Originally Posted By MIKES_DUSTER
Bullet Cams
X2
Joey
Re: Who's flat solid cam? SB [Re: B3422W5] #1840067
06/02/15 10:22 PM
06/02/15 10:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same here as Dwayne speced and ground my cam and supplied the EDM lifters and I could not be happier. Ron
Re: Who's flat solid cam? SB [Re: qwkmopardan] #1840194
06/03/15 12:42 AM
06/03/15 12:42 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
How much compression does the STX-21 need to work well?
Yeah, it's got a smallblock.
Re: Who's flat solid cam? SB [Re: justinp61] #1840228
06/03/15 01:34 AM
06/03/15 01:34 AM
Washington
skrews Offline
skrews  Offline
Washington
X 3 for Bullet
Re: Who's flat solid cam? SB [Re: skrews] #1840299
06/03/15 07:49 AM
06/03/15 07:49 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Clay Smith Cams.
Re: Who's flat solid cam? SB [Re: justinp61] #1840333
06/03/15 10:05 AM
06/03/15 10:05 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Predator cam Mt Carmel pa. He has lots of different Mopar cam cores.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
