Throttle pedal
#1837746
05/31/15 03:52 AM
05/31/15 03:52 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
The stock throttle pedal in my '63 will not give me full throttle without hacking it up. What have you guys done to give the throttle cable a bigger pull?
Re: Throttle pedal
[Re: DaveRS23]
#1838032
05/31/15 03:17 PM
05/31/15 03:17 PM
Posts: 43,727 Bend,OR USA
Cab_Burge
Re: Throttle pedal
[Re: DaveRS23]
#1838033
05/31/15 03:18 PM
05/31/15 03:18 PM
hemi-itis
I'm goin down to the garage and removing the pedal assembly and see what I can mess up next!
Re: Throttle pedal
[Re: RT540]
#1838168
05/31/15 07:47 PM
05/31/15 07:47 PM
Posts: 12,477 Taxes & Virus's R-US, NY
Dragula
If you move the small uniball closer to the shaft it will open more. When I zoom in it looks like you have one hole already there, closer to the shaft. Same thing I had to do...I ran it low on the carb. A lot lower than I wanted, but its been working.
Re: Throttle pedal
[Re: B G Racing]
#1838646
06/01/15 01:14 PM
06/01/15 01:14 PM
hemi-itis
Find a floating gas pedal fron an A-body and mount it to the firewall. Bob,Lokar has a wide choice of pedel assemblys for "A" bodies and none for the b's.Is the bolt pattern the same???
Re: Throttle pedal
[Re: hemi-itis]
#1838855
06/01/15 04:54 PM
06/01/15 04:54 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Find a floating gas pedal fron an A-body and mount it to the firewall. Bob,Lokar has a wide choice of pedel assemblys for "A" bodies and none for the b's.Is the bolt pattern the same??? You're a hot rodder, man!! Make an adapter plate, if need be!! Anything can be made to fit!!
Gone to the dark side with an LS3 powered '57 Chevy 210
