Re: Can you covert an a body auto shifter to a slapstick?
[Re: DodgeCharger]
#1839679
06/02/15 01:11 PM
06/02/15 01:11 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
What plate did he swap in ?
I've seen E body console swapped into an A body MANY moons ago , should be able to swap one in, might take a little creative blending to make it look factory .
[Re: DodgeCharger]
#1839767
06/02/15 03:06 PM
06/02/15 03:06 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Yep, that's how they work and how they are different, not exactly like a slapstick but a lot better than stock if you want to race it and shift manually and not worry about throwing it into neutral or reverse.
The sticking part can be helped with adjustments like adjusting how many turns in the shift button/knob is and I think there is some adjustment with how the gate is mounted. Like I said you have to fiddle around a bit. A lot people don't like these because they haven't done the fiddle around part yet to get it just so.
