Re: Who's flat solid cam? SB
[Re: justinp61]
#1839549
06/02/15 09:20 AM
06/02/15 09:20 AM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
I have always called Dwayne Porter, and had him spec and order a cam for me. He is the man
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: justinp61]
#1839630
06/02/15 12:15 PM
06/02/15 12:15 PM
Posts: 7,506 Az
Crizila
Az
I'm need a flat solid cam for my 340, the hydraulic in it now is bad. This is the motor I built for my Dart in 03 and replaced it with a 408 in 09. I bagged the short block and put it on a shelf.
Over the winter I pulled the 408 to freshen it and found some odd cam and main bearing wear and the flat solid cam was on it's way out. I bought a 395" R1, Indy head motor, sold the rotating assembly and am gathering parts for a 434" build.
So..........I thought I'd bring the 340 out of moth balls, put the heads and intake back on, check the bearings and run the pi$$ out of it until I have the new motor built. Wrong! While looking it over today before mounting it on the engine stand I noticed some pitting on the nose of one of the lobes. After closer inspection there is another lobe showing the same, so this cam was on it's way out too. Both cams were from the same company and had been ran for about five years.
I need another cam. Who do you guys recommend? Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years.
Fastest 300
[Re: B3422W5]
#1839658
06/02/15 12:39 PM
06/02/15 12:39 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
[Re: qwkmopardan]
#1839677
06/02/15 01:10 PM
06/02/15 01:10 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. Totally agree with this.
[Re: Crizila]
#1839740
06/02/15 02:26 PM
06/02/15 02:26 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years. I haven't miced the cam. The 340 cam has two lobes that have pitting on the nose of the cam. one of the lobes shows wear all the way across the lobe with pits that will catch you fingernail. The bottom of that lifter looks to have been hit with a tiny needle scaler. The other lobe is just starting to pit. The rest of the lifters and lobes look perfect. The 408 had EDM lifters in it and has several lobes and lifters as I described above.
[Re: justinp61]
#1839810
06/02/15 03:51 PM
06/02/15 03:51 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Did you mic that cam to be sure it is bad? How did the lifter look? I have had good luck with Hughes cams over the years. I haven't miced the cam. The 340 cam has two lobes that have pitting on the nose of the cam. one of the lobes shows wear all the way across the lobe with pits that will catch you fingernail. The bottom of that lifter looks to have been hit with a tiny needle scaler. The other lobe is just starting to pit. The rest of the lifters and lobes look perfect. The 408 had EDM lifters in it and has several lobes and lifters as I described above. What company? Was it a big cam? What oil were you using?
[Re: B3422W5]
#1840067
06/02/15 10:22 PM
06/02/15 10:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have always called Dwayne Porter, and had him spec and order a cam for me. He is the man Same here as Dwayne speced and ground my cam and supplied the EDM lifters and I could not be happier. Ron
[Re: qwkmopardan]
#1840194
06/03/15 12:42 AM
06/03/15 12:42 AM
Posts: 1,532 off the grid
340B5
off the grid
Racer Brown. Call Jim at 1-410-866-7660. Hope his business didn't get burned down as he is in Baltimore MD. ST-21 for street/strip or STX-21 for a car w/some compression, converter, and gear. Jim will get you set up with a perfect cam for your combo. How much compression does the STX-21 need to work well?
Yeah, it's got a smallblock.
[Re: justinp61]
#1840333
06/03/15 10:05 AM
06/03/15 10:05 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Predator cam Mt Carmel pa. He has lots of different Mopar cam cores.
Brett Miller W9 cnc'd heads STR Chassis fabraction
