71/72 B body Tach Question #1837488
05/30/15 09:01 PM
05/30/15 09:01 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
My 72 RR 4 speed car did not come with a factory tach...I have a real cool Mopar tach but im not sure where I should mount it for both looks and function...Can some of you with 71/72 B bodied cars show me where you have one mounted to get some ideas..Any place that does not butcher the originality like through the dash pad !!! popcorn
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: 71/72 B body Tach Question [Re: 72N96RR] #1837508
05/30/15 10:02 PM
05/30/15 10:02 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
why not install a factory tach from a 71-72 B body.
perception is 90% of reality
Re: 71/72 B body Tach Question [Re: Mr T2U] #1837514
05/30/15 10:23 PM
05/30/15 10:23 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Because all the existing gauges would have to be changed...
Re: 71/72 B body Tach Question [Re: 72N96RR] #1837573
05/30/15 11:36 PM
05/30/15 11:36 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I simply mounted mine on the steering column w a oversized clamp available at any autoparts store.
Re: 71/72 B body Tach Question [Re: 72N96RR] #1837575
05/30/15 11:37 PM
05/30/15 11:37 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Re: 71/72 B body Tach Question [Re: moparjim79] #1837662
05/31/15 12:38 AM
05/31/15 12:38 AM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Back in 1977 when I bought my first 72 Satellite I just loosened the map and seatbelt assembly that is screwed to dash and slide the flat part of the tach's bracket under the edge and then re-tightened the screws.
On this Satellite I did it the factory way.
Ron
Re: 71/72 B body Tach Question [Re: 72N96RR] #1837818
05/31/15 10:27 AM
05/31/15 10:27 AM
Mr T2U Offline
Mr T2U  Offline
i am sorry, I assumed your RR had the rally dash with a clock instead of a tach.
this is how my 72 RR was.
all I did was buy a repo tach from charger specialties and wired it in. only took a couple hours to do it.
Re: 71/72 B body Tach Question [Re: Mr T2U] #1837868
05/31/15 11:41 AM
05/31/15 11:41 AM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Never saw a 72 RR without a ralley dash so don't get the response either.
Ron
Re: 71/72 B body Tach Question [Re: RJS] #1837897
05/31/15 12:24 PM
05/31/15 12:24 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Ron
there are 2 different rallye clusters
one came with either a clock or tach
one came without both a clock or tach
the one without has a totally different gauge layout
so it will not accept a tach or clock
it has no room for either of them.
Re: 71/72 B body Tach Question [Re: flypaper] #1838018
05/31/15 02:54 PM
05/31/15 02:54 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Your right I forgot about that, it would have been easier if the OP would have just showed us his dash instead of the outside of the car from the beginning.
Ron
Re: 71/72 B body Tach Question [Re: RJS] #1838065
05/31/15 04:54 PM
05/31/15 04:54 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Ron
I asked where some of you have mounted a tach in your 71/72 b bodied car and its my fault for not showing a picture of my dash..??
Re: 71/72 B body Tach Question [Re: flypaper] #1838066
05/31/15 04:57 PM
05/31/15 04:57 PM
Mr T2U Offline
Mr T2U  Offline
I didn't know there were 2 different rally dashes for 72 B bodies. I will have to try to remember that.
I thought the only differences were in the 73-4 bezels with the extra light areas above the switches.
I have mostly worked on E bodies.
Re: 71/72 B body Tach Question [Re: Mr T2U] #1838068
05/31/15 05:02 PM
05/31/15 05:02 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
Trust me Id love the factory installment...But its a whole new dash cluster which id rather keep original..Mainly due to the low mileage and originality of the vehicle..
Re: 71/72 B body Tach Question [Re: Mr T2U] #1838181
05/31/15 08:05 PM
05/31/15 08:05 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Just to clarify.
There are 3 different Rally dash GUAGE layouts.
1. with clock (speedo in large left pod, clock in large right pod, and the 2 smaller pods have 2 guages each)
2. with Tach (same as Clock layout, but has a Tach in the large Right pod)
3. NO clock OR tach (speedo in Large left pod, 2 guages in large right pod, and 1 guage each in each of the small pods.)
Woodgrain on the 71-3 is the same. 73's did't get the extra light icons. The 74 woodgrain is the only odd ball, as those extra light icons were required by the government starting with the 74 model year.
smile
Re: 71/72 B body Tach Question [Re: 440trk] #1838202
05/31/15 08:28 PM
05/31/15 08:28 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
It's even more complex then that.. lol
The cluster frame itself is totally different for a 71
To be able to accept the 71 only wiper
switches...
so there were more then 3 versions of that cluster
71 was its own animal for a lot of things..
Re: 71/72 B body Tach Question [Re: flypaper] #1839294
06/01/15 11:12 PM
06/01/15 11:12 PM
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
switches...
I believe that...Ive owned early and late built 72RRs that had many differences as well..
My dash looks like the number 3 that Mike 440TRK described...
Re: 71/72 B body Tach Question [Re: 72N96RR] #1839706
06/02/15 01:43 PM
06/02/15 01:43 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
switches...
Then if you have the seatbelt/maplight assembly what I posted in the beginning of this post will be the least intrusive way to mount a Tach.
Ron
Re: 71/72 B body Tach Question [Re: RJS] #1839978
06/02/15 08:32 PM
06/02/15 08:32 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Under the dash on an angle. Used existing holes under dash. I have a picture but don't know how to attach
Re: 71/72 B body Tach Question [Re: gygeneral] #1839987
06/02/15 08:46 PM
06/02/15 08:46 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Originally Posted By gygeneral
Under the dash on an angle. Used existing hoes under dash. I have a picture but don't know how to attach
i'd love to see some pics of the hoes under your dash. apimp
