E body trunk light
#1838157
05/31/15 07:34 PM
05/31/15 07:34 PM
Posts: 4,104 Horsham, Pa.
Finoke
Horsham, Pa.
I have an NOS e body trunk wiring harness that I think I will use on the Cuda that I'm assembling. It came with a parts lot that I bought awhile back.
Is this the fixture that operates on a mercury switch? Is the Mercury switch internal to the bulb socket?
Also, what size bulb does it take and where can I get the clip to hold the wire to the trunk hinge?
Thanks Tom
Re: E body trunk light
[Re: Finoke]
#1838368
06/01/15 01:18 AM
06/01/15 01:18 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Brass based 1003 or 1004 bulb. From the FSM. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: AARCONV]
#1838473
06/01/15 09:34 AM
06/01/15 09:34 AM
Finoke
Horsham, Pa.
switch is in the socket, the plastic clip I found on ebay,bulb ? I forgot..but isnt that a bulb in the picture? Thanks! I removed the bulb from my convertible to get the number but it wasn't marked. Its not burned out so I put it in the black cuda. Now I need to replace the one I took from my convertible This car has been a lot easier to put together since I have another sitting beside it
[Re: denfireguy]
#1838475
06/01/15 09:37 AM
06/01/15 09:37 AM
Finoke
Horsham, Pa.
Brass based 1003 or 1004 bulb. From the FSM. Craig Thanks Craig! I have a FSM but didn't think to look for bulb size there. Excellent!
