Re: Turbo cams?
[Re: Randy..]
#1836523
05/29/15 10:45 AM
05/29/15 10:45 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The bigger turbo/billet wheel/race cover will move the compressor efficiency up and to the right. That is a good thing when you're running big boost levels and turning a bunch of RPM.
However since you're running at such low boost I would actually expect to see the IAT get slightly worse at 9psi. Why would that pick up 50hp?
What trendz is trying to say is that different turbo's, CID, boost level, heads, etc... Will all want a different cam grind. Some combination of the above will be more like a Na cam, and some will want something more obscure.
Some turbo cams are ground with a reverse split duration, some are not.
Too many factors go into it to generalize anything.
Re: Turbo cams?
[Re: Randy..]
#1842561
06/05/15 11:34 PM
06/05/15 11:34 PM
Posts: 791 Bama
Randy..
Bama
Well gonna run the Comp I have unless someone buys it from me, It will run what it runs, this is my first v8 turbo, It will run good I'm shur, and when I get another block and rotating assy I can lean on I will buy a "proper" cam.
Re: Turbo cams?
[Re: Randy..]
#1842591
06/05/15 11:50 PM
06/05/15 11:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well gonna run the Comp I have unless someone buys it from me, It will run what it runs, this is my first v8 turbo, It will run good I'm shur, and when I get another block and rotating assy I can lean on I will buy a "proper" cam. Thats just a N/A cam.. if I were you I would do some calling to get a proper cam.. something in the 114 LSA... you can sell that cam latter
Re: Turbo cams?
[Re: Randy..]
#1842778
06/06/15 11:04 AM
06/06/15 11:04 AM
dizuster
Oakland, MI
Before you get started on this project and disapoint yourself... The link below is a borg warner 75mm compressor map at only 10psi of boost on a 500" motor (assuming a 4.25" crank and 4.34 bore). As you can see you are off the entire page (let alone the chart!) by 5000 RPM. A cam that is 283@.050" is going to want to spin fairly high RPM, which will be a terrible match with this turbo. To make a 75mm work on a motor this small, you'll only be able to turn it to around 5000 RPM, which would literally mean stock cam. If you want to turn it to a lot of RPM, then you need a much bigger turbo. Just don't want to see you spend a lot of time and effort putting a bunch of mismatched parts together... http://www.turbos.bwauto.com//aftermarke...rsin=92044&
