Page 2 of 5 1 2 3 4 5
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835296
05/27/15 02:59 PM
05/27/15 02:59 PM
pennsylvania
poboyengineering Offline
pennsylvania
Much better pictures than what I saw at BSD! Really enjoyed our talk, Mike. That is a ton of work. Don't you love parts that offer a "Bolt on performance increase"!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Another Edelbrock Victor Saga [Re: Airwoofer] #1835340
05/27/15 03:44 PM
05/27/15 03:44 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Originally Posted By Airwoofer
Good luck getting a spring pressure measuring tool in there!
The stands aren't any wider than the original hold downs, so I doubt he will have any trouble there.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Another Edelbrock Victor Saga [Re: MR_P_BODY] #1835345
05/27/15 03:47 PM
05/27/15 03:47 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Originally Posted By MR_P_BODY
Originally Posted By B3RE
Originally Posted By BradH
Not my Victors, but I'm still interested in this thread.
Is that combination going to need valve cover spacers now?
He has pretty tall fabbed valve covers, so I doubt it. The real problem is side clearance. Edelbrock raised the rail on these heads, but they went straight up instead of on the incline of the valve, and that crowds the tail end of the rocker. You definitely couldn't use a cast cover.
On my SB stuff I have to use reverse lip valve
covers and still have to notch the lip of the
cover and the gasket to clear
wave
Yeah Mike, the fabbed covers have that reverse lip. If the rockers weren't so darned long, some of those issues could be eliminated.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835347
05/27/15 03:48 PM
05/27/15 03:48 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
This thread reminds me of something I forgot to do...
Very cool pics and info sir. Very similar to my stuff sans the stands.
Re: Another Edelbrock Victor Saga [Re: clonestocker] #1835351
05/27/15 03:53 PM
05/27/15 03:53 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Originally Posted By clonestocker
B3RE,
Love your threads and you did some work for a buddy in Tucson. My question would be wouldn't a shorter valve help the situation out? I'm sure the valve lift has something to do with the length of valve that can be used? Just curious. thx matt
Yes Matt, a shorter valve would have made it less "off", but he was shooting for that elusive 2.00" installed height to run that much lift. Getting 2.100" will be rough with that valve cover rail location. There likely won't be room for that much offset.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: GTS340] #1835353
05/27/15 03:55 PM
05/27/15 03:55 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Originally Posted By GTS340
Very nice work Mike!
Seems like I remember a certain genius member calling your product "snake oil" and saying that your attention to detail on rocker geometry offers no benefit, I wonder what his view would be on this specific application.
Shhhhhhh! I use the snake oil as a machining lubricant.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: BradH] #1835361
05/27/15 04:00 PM
05/27/15 04:00 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Oh, don't forget to drill & tap the center stud location to accept the longer studs like in the #2 & #4 shaft hold-down positions. There have been a number of center pedestal cracking reports on here, and I wouldn't run a Victor head w/o this mod now. twocents
I didn't drill the center deeper, but it has the additional support screws in the three center stands, so it is very rigid. I know the center stand is thin, but I have to wonder if the cracking issue isn't from valvetrain instability. After all, it breaks enough other parts.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: poboyengineering] #1835363
05/27/15 04:02 PM
05/27/15 04:02 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Thanks Tom, I enjoyed the conversation as well. Amazing how much better digital pics look out of the bright sunshine.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: Jeremiah] #1835369
05/27/15 04:05 PM
05/27/15 04:05 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Hey Jeremiah, didn't you beat on that thing yet?
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835370
05/27/15 04:06 PM
05/27/15 04:06 PM
P
Porter67 Offline
Porter67  Offline
P
That's some nice looking quality work. I like how the bottoms are done vs like the offset W2 stands which are flat as you know. I don't know how anyone would expect them not to take a lot of work to set them up correctly.
If you can post it whats the spring height and are they longer then delived valves? I don't know BB specs but just wondering.
Re: Another Edelbrock Victor Saga [Re: Porter67] #1835388
05/27/15 04:29 PM
05/27/15 04:29 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Thanks for the compliments guys!
The engine builder was shooting for a 2.00" installed height, and the valves were Ferrea and REV. The customer bought the heads CNC ported bare from Hughes, so the valves are the builders choice. I don't think they are much longer, if any, than stock Edelbrocks, because he he still needed that deep retainer to get the 2.00". I only moved the rockers to where they needed to be to get the proper geometry.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835411
05/27/15 05:10 PM
05/27/15 05:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Jeez, that's a he11uva lot of work to get that combination straightened out.
My stock-valve (Edelbrock supplied) Victors w/ the Hughes rockers didn't look nearly that jacked up when I mocked 'em up. Mine are set up for a 1.900" installed height using ti retainers and +.050" locks.
I'll still look for what they'd need to optimize the geometry, though.
Re: Another Edelbrock Victor Saga [Re: BradH] #1835499
05/27/15 08:09 PM
05/27/15 08:09 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
It was a lot of work, but they were for an 8 sec., 10.5 tire car. The builder wanted the best that the customer could afford.
I'd be willing to bet yours are still off a good bit, even at 1.900", but like Jeremiah's Victors with Hughes rockers, it should be a lot less work. It just doesn't make sense to spend a lot of money on good parts, and then not have them set up correctly.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835556
05/27/15 09:20 PM
05/27/15 09:20 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Should have just went B1s more up front but ALOT less machine work.
Re: Another Edelbrock Victor Saga [Re: Randy..] #1835558
05/27/15 09:27 PM
05/27/15 09:27 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
That would have required different pistons and other specialized parts. From the story I got, he was running Indys and the seats fell out of them, so he went Edelbrock.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835569
05/27/15 09:45 PM
05/27/15 09:45 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Good buisiness for you, great work.
Re: Another Edelbrock Victor Saga [Re: Randy..] #1835592
05/27/15 10:30 PM
05/27/15 10:30 PM
USA
B3RE Offline OP
B3RE  Offline OP
USA
Thanks Randy.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835653
05/27/15 11:49 PM
05/27/15 11:49 PM
gregsdart Offline
gregsdart  Offline
Looks plenty stout, Mike. With the lift stated and good care, the valve train ought to live to a ripe old age!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Another Edelbrock Victor Saga [Re: gregsdart] #1835720
05/28/15 01:00 AM
05/28/15 01:00 AM
USA
B3RE Offline OP
B3RE  Offline OP
USA
I hope so Greg. I know the customer isn't anxious to spend more money on the valvetrain any time soon. Can't say that I blame him.
Mike Beachel
Re: Another Edelbrock Victor Saga [Re: B3RE] #1835740
05/28/15 01:34 AM
05/28/15 01:34 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
very good work!!!!!
