Lifter Noise on 2014 Ram 1500?
#1834813
05/26/15 08:40 PM
05/26/15 08:40 PM
Posts: 3,038 N.W. Florida
Fat_Mike
N.W. Florida
A friend has a '14 Ram with the EDIT: 5.7 HEMI. On cold start up it has a rattling noise that sounds exactly like a lifter to me. It only makes the noise for about a second, then goes away. Doesn't do that when restarted warm, only upon a cold start (sat for about 4 hours when I heard it). I looked for a service bulletin on the web and couldn't find one. He's taking it to the dealer to get checked out sometime this week. Anyone else having this problem, or know of a service bulletin that I couldn't dig up?
Re: Lifter Noise on 2014 Ram 1500?
[Re: NITROUSN]
#1835197
05/27/15 12:17 PM
05/27/15 12:17 PM
Fat_Mike
N.W. Florida
I'll have to ask. It has less than 7,000 miles, and he uses the trucks computerized "oil life" system to dictate when he changes oil. Unless there was a something like a 500 mile service, it may have never had the oil changed. I'll find out... Edit: I'm really more interested to know if it's a known/documented problem so he doesn't get BS'd by the dealer when he takes it in. It's under warranty, so they'll fix whatever it is if they take the time to duplicate the problem. Regardless, I'll get the answer to your question.
[Re: Fat_Mike]
#1835214
05/27/15 12:54 PM
05/27/15 12:54 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Most modern day engines seem to be pretty noisy on startup. My wife's 2010 Edge is, My 08 Ram was, we have a few new vans in our fleet at work and they all sound kinda crappy when cold, and fine when warm.
Our 06 beater van at work with 240K on the clock doesn't make a sound when cold though LOL.
68 Barracuda Formula S 340
[Re: NITROUSN]
#1835565
05/27/15 09:41 PM
05/27/15 09:41 PM
Posts: 7,664 IN
ahy
IN
What oil and what filter is he using? I had that on a 5.7 after oil change at a quick lube. The filter had no check valve and let oil drain back. A MOPAR filter fixed it. Also a slight chance its an exhaust leak/warped manifold that sounds like a lifter. I had a left manifold that would only leak when cold then sealed up. I took I to a dealer and they said manifold leak... new manifold fixed it (over 100k).
[Re: ahy]
#1835918
05/28/15 12:36 PM
05/28/15 12:36 PM
Fat_Mike
N.W. Florida
I had that on a 5.7 after oil change at a quick lube. The filter had no check valve and let oil drain back. A MOPAR filter fixed it. Wow, who would have thought. EDIT: He just told me that it has its original oil and filter at less than 7K miles. Oil life indicator says it has 15% oil life remaining, which he'll have changed at the dealer while they're looking at this other issue.
[Re: Fat_Mike]
#1836087
05/28/15 04:59 PM
05/28/15 04:59 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
A lot of stuff going on inside that newer engine with the MDS, VCT junk in it so I have heard several almost new trucks with little ticking noises like that at start up.
[Re: Fat_Mike]
#1840357
06/03/15 11:05 AM
06/03/15 11:05 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I can only say it is not typical. Mine does not do that. The recommended oil change interval is 10K. I did that for the first change but now doing it at 8K, same as our fleet where I work. I did have to have an oil sensor replaced last week that threw a code. I am at just over 22,000 right now. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
