Re: New EFI Fuel tanks!
[Re: 451Mopar]
#1834353
05/26/15 04:56 AM
05/26/15 04:56 AM
Posts: 4,848 Memphis
HemiRick
Memphis
With an Aeromotive Phantom system you can do this yourself...no waiting either
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 451Mopar]
#1834472
05/26/15 12:27 PM
05/26/15 12:27 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
With an Aeromotive Phantom system you can do this yourself This doesn't compare to a properly baffled EFI tank.
[Re: Stanton]
#1834509
05/26/15 01:21 PM
05/26/15 01:21 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
With an Aeromotive Phantom system you can do this yourself This doesn't compare to a properly baffled EFI tank. According the them it has "EFI style internal baffling" I plan to run a Walbro TIA485-2 pump that is 450 lph and works with E-85. I was going to make my own tank, but I just might try one of these out. No specific release date, they just said it would be a few months? I'm not sure if the A and E-body tanks are already done, the web page says "New", where the B-Body tanks say "Coming Soon"? I though it was cool that someone would manufacture these at an affordable price. Right now I just have a sump kit welded to a stock tank and an external in-line fuel pump. I don't care for the look of the sump and external pump, that is why I'm interested in these tanks.
[Re: 451Mopar]
#1834680
05/26/15 05:38 PM
05/26/15 05:38 PM
Posts: 3,288 West Coast, USA
jbc426
West Coast, USA
The vast majority of baffeled tanks currently available are not capable of providing air free fuel unless they are at least half full. Even modern EFI cars are having issues with air bubbles getting into the high pressure fuel lines. Most serious EFI systems are using a surge tank to suplement and eliminate the air bubble problem on the high pressure side.
I am using a surge tank in my '68 Barracuda with a stock fuel tank and exterior mounted pusher pump, it can be run as low as 2 gallons with no air getting in my high pressure side.
It also keeps the high pressure plumbing much shorter, as it is mounted at the front of the car.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 451Mopar]
#1834775
05/26/15 07:49 PM
05/26/15 07:49 PM
Posts: 4,761 Florida
BDW
It looks like Spectra is offering tanks with EFI, and from RockAuto no less, great price, but not a lot of details. https://www.rockauto.com/catalog/raframecatalog.php?make=DODGE&ck[year_1995]=true&ck[mkt_US]=true&ck[mkt_EU]=false&ck[mkt_CA]=false&ck[mkt_MX]=false&ck[viewcurrency]=USD&ck[ID]=0&ck[idlist]=0&ck[PHP_SESSION_ID]=bdifjnmrn1f8a71ibc9uqcthm7
[Re: jbc426]
#1834846
05/26/15 09:42 PM
05/26/15 09:42 PM
Challenger 1
Cincinnati, Ohio
It also keeps the high pressure plumbing much shorter, as it is mounted at the front of the car. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) with you. You are exactly correct imo. Save your money on a custom built fuel tank, keep your stocker (fuel tank and pump) and put that money toward the sump and fuel pump. You'll be at least 500 bucks ahead...Just as long as you have room in front for the sump. BTW not a new idea at all. I know guys who had front mounted custom fuel sumps up front with holley fuel bowl for floats on them that gravity feed a mechanical fuel pump for mechanical fuel injection, 25 years ago. Now with submerged pumps any mounting is possible. Very slick way of providing hi pressure fuel for a old muscle car like ours. Everyone should look into it, imo.
[Re: 451Mopar]
#1835003
05/27/15 01:17 AM
05/27/15 01:17 AM
Posts: 1,822 Colorado
denfireguy
Colorado
They show the tanks for my car as being available now from Tanks Inc. It changed last Friday. Spectra pushed some prototypes out through their dealer network in very limited quantities and they sold out quickly. A Spectra dealer told me in a few months they are supposed have them in production quantities. Not sure if I am going to get the Spectra or Tanks. Main thing that I do not know the quality of the fuel pump in the Spectra. Warbro in the Tanks is known quality. The Spectra uses hoses with clamps while the Tanks uses -AN fittings that I like better. Both of them use after market gauge senders and that has been an issue with many. Tanks holds one more gallon of fuel and both hold more than the stock tank. Tanks has a recess to route the hoses and wiring, Spectra is in the same spot as the stock tank. The both look stock from the rear. My stock tanks needs replacing as it is seeping at the seems. I am hoping that an in tank pump is quieter than the Edelbrock pump I am using now. I am going to go for one or the other in the next few weeks. As for the sump, the price of a sump and a replacement tank is more than an EFI tank and pump so that is the way I am going to go. Just not sure which one. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 451Mopar]
#1835386
05/27/15 04:27 PM
05/27/15 04:27 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
As much as that at face value seems to be a plus, adding a considerable bit more plumbing, tank, wiring, etc, that still includes high pressure, in a area rather venerable in our older cars in even a minor shunt, seems to possibly offset that upside. So you're saying it makes more sense to have the entire system from the rear of the car under high pressure than just the front-mounted sump !?!?!?! Less plumbing than a full return system. Wiring - to the front or to the rear - what's the difference? The sump system is about as compact as any "in tank" system. The installation of a sump versus any other efi pump system is just so much simpler and faster. The sump just makes way more sense. You just need to find one that supports your HP. The Edelbrock one is pretty slick but makes no mention of what kind of HP is can support.
[Re: 451Mopar]
#1835716
05/28/15 12:59 AM
05/28/15 12:59 AM
denfireguy
Colorado
denfireguy, are you going the the Mopar show at Bandimere Sunday? I think I will take the '69 Convertible. I won't have the Charger together by Sunday. I am going to be there but they tore up the driveway behind my townhome three weeks ago to pave and then the rains came. I cannot get it out of the garage now.
[Re: denfireguy]
#1835800
05/28/15 05:54 AM
05/28/15 05:54 AM
451Mopar
Aurora, Colorado
denfireguy, are you going the the Mopar show at Bandimere Sunday? I think I will take the '69 Convertible. I won't have the Charger together by Sunday. I am going to be there but they tore up the driveway behind my townhome three weeks ago to pave and then the rains came. I cannot get it out of the garage now. Hope for good weather this weekend. See you and Dynorad at Bandimere.
