Checking flash on converter with trans brake #1833421
05/24/15 08:16 PM
05/24/15 08:16 PM
Illinois
Mopar_Ray Offline OP
Illinois
I want to check the flash on my converter. Converters a 9.5 PTC.Running a MSD AL3 box. Griner brake. Currently have a 3000 chip in the launch controller. If I remove the chip,use the brake, start the car and stab the pedal, the playback tachometer should show me the flash stall on my converter, correct?
Re: Checking flash on converter with trans brake [Re: Mopar_Ray] #1833426
05/24/15 08:22 PM
05/24/15 08:22 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
It will show the stall speed. Make sure the car is on stands.
Re: Checking flash on converter with trans brake [Re: CMcAllister] #1833433
05/24/15 08:45 PM
05/24/15 08:45 PM
Illinois
Illinois
Planning to do it on street before taking to strip.
Re: Checking flash on converter with trans brake [Re: Mopar_Ray] #1833459
05/24/15 09:34 PM
05/24/15 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah.. pull the chip(launch chip) and stab it... thats the way
I launch all the time... do it in a area thats safe.. just in
case
wave
Re: Checking flash on converter with trans brake [Re: Mopar_Ray] #1833735
05/25/15 10:50 AM
05/25/15 10:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Just watch the playback at the track. Why take a chance hurting the converter? Converter is already in the car. Why do you need the stall number before it hits the track? It is what it is.
Doug
