70 SuperBee rust... #1826485
05/14/15 10:56 AM
05/14/15 10:56 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I'm looking to slow down the small surface rust areas and little paint lifting spots on my Bee...I know there is some products out there....but I also understand that once you open the can..or bottle that you have to use it right away.....I'm wanting to do it on weekends and it small amounts......HELP.... Any suggestions....Thanks..I'll get some pics posted
Re: 70 SuperBee rust... [Re: Hemiruss] #1826905
05/14/15 09:59 PM
05/14/15 09:59 PM
FLA
JohnnyBee Offline
JohnnyBee  Offline
FLA
Don't open the can.
Use a rivet for the hole to pour out what you need, then put the rivet in to seal the hole. Rivet works best because when done you pop the rivet and seal the hole. tip the can upside down once and back upright and that seals the inside of the rivet. Use a new rivet and new hole. I also put the can in a plastic bag and get all the air out that you can. It keep it a little longer.
hope this helps
Re: 70 SuperBee rust... [Re: JohnnyBee] #1827072
05/15/15 02:49 AM
05/15/15 02:49 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
What product do you think is the best to use...
Re: 70 SuperBee rust... [Re: Hemiruss] #1827361
05/15/15 04:46 PM
05/15/15 04:46 PM
FLA
JohnnyBee Offline
JohnnyBee  Offline
FLA
have only worked with POR-15
Re: 70 SuperBee rust... [Re: Hemiruss] #1829937
05/19/15 12:09 PM
05/19/15 12:09 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Thank you...I'll search around and get some......
Re: 70 SuperBee rust... [Re: Hemiruss] #1830687
05/20/15 11:42 AM
05/20/15 11:42 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use Magnet Paints chassis saver, they sell it at the local carquest and napa stores. You can buy it on ebay also. Cheaper than por 15 and other. I think it works better too. I have had gallons last for years... as long as you make sure you seal the lid good.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 SuperBee rust... [Re: Hemiruss] #1831304
05/21/15 07:42 AM
05/21/15 07:42 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I Have some small paint chips that are lifting...and small surfaced rust areas....it's a survivor so I want it to last a lot longer.....before I consider any kinda resto.
Re: 70 SuperBee rust... [Re: Silver70] #1833197
05/24/15 12:49 PM
05/24/15 12:49 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Silver70 is this going to be a clear product??? I need to dab something on the little paint chips and areas that are lifting.Im trying to slow down to "Rust Monsters" that like to eat cars......
Re: 70 SuperBee rust... [Re: Hemiruss] #1833218
05/24/15 01:42 PM
05/24/15 01:42 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
No this stuff is black, they make silver also. Can you take any pics of the areas your talking about?
