Re: Where do y'all by electrical parts for early 80's trucks?
[Re: wyldebill]
#1833086
05/24/15 02:07 AM
05/24/15 02:07 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
used may be all that is available. boneyards, here...
1981 Dodge D150 360 auto
[Re: wyldebill]
#1833116
05/24/15 08:38 AM
05/24/15 08:38 AM
Posts: 27,728 places
79powerwagon
places
Is it dash mounted still? Might it be the same as earlier cars? I've never had one fail on all of these trucks I have owned. And I'd bet we use the wipers up here 100's of times more then you do in Texas. I've gone thru many headlight switches, but never a wiper switch. Look at the part and see if it matches a popular car switch.
[Re: basketcase]
#1833228
05/24/15 02:02 PM
05/24/15 02:02 PM
Posts: 16,808 Between Houston & Galveston TX
SattyNoCar
Out of curiosity, I did a search myself.... I guess ALL vintage Mopars are now show poodles? Didn't matter if it was a truck or a car, I can find headlight switches no problem, but, ZERO wiper switches. I'd be willing to bet it would interchange with a '70's A-body switch. Later ones had electric windshield washer built in. Aside from that, and going used, maybe a generic switch? Its a pretty basic switch, here's one I found: Wiper Switch As an aside, I had an '84 that needed its heater control panel replaced (fan switch overheated and took it out). Came to find out, it was identical to one I had in my parts stash from a '77 FURY (B-body). No mods at all to install it. Chrysler wasn't known to reinvent the wheel every year when it came to stuff like this, so, chances are good you can find something off an earlier car/truck that will work.
John
[Re: wyldebill]
#1833255
05/24/15 02:51 PM
05/24/15 02:51 PM
Posts: 516 ND
dodgedon
ND
So this is a 2 speed wiper switch? Do you have a part number?
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: wyldebill]
#1833542
05/24/15 11:32 PM
05/24/15 11:32 PM
Posts: 516 ND
dodgedon
ND
3747333 is a good number. Valley vintage says they have 2. Arizona parts says they have 5. Silkes auto has 4. Just look them up on the web and call to be sure that this is the number you are looking for.
Have you done a check of the motor? The service manual lists a procedure for "Motor will keep running with switch in park or off position" If not I can type that out for you too.
[Re: wyldebill]
#1833717
05/25/15 10:19 AM
05/25/15 10:19 AM
79powerwagon
places
[Re: 79powerwagon]
#1833746
05/25/15 11:14 AM
05/25/15 11:14 AM
Posts: 516 ND
dodgedon
ND
The manual list many different "Conditions" This is.....Motor will keep running with switch in park or off position.
Look at the motor with the motor on left and the 4 wire plug pointing down to the right. The terminals are from left to right L, P1, P2, H. They may be marked on the plug.
Procedure....Remove wiring harness (Plug). Connect jumper from terminal P2 to terminal L (On motor). Connect second jumper from terminal P1 to battery. If motor runs to park position and stops, switch is faulty. If motor keeps running and does not park, replace motor assembly.
Thats all there is to it, let us know what you find out.
