69 Belvedere 4 door to 2 door conversion
#1832092
05/22/15 12:28 PM
05/22/15 12:28 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I bought this car over a month ago on ehay. Looked too cool for the price to pass up and wasn't much info in the auction. Someone talked me into buying it, so took a chance without more info since it was in the south west. I figured worst case good parts car. Well it arrived, floor was shot, lots of wiring and stuff I didn't like plus a slant 6/3 speed with a floor shifter I couldn't shift well I didn't want to put $ into a 4 door so decided instead of cutting up for parts, I'd make it into something I'd like. So here it is, the not as easy a the older b-body 4 to 2 door conversion. How it looked when it arrived:
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 69 Belvedere 4 door to 2 door conversion
[Re: Silver70]
#1832093
05/22/15 12:31 PM
05/22/15 12:31 PM
Silver70
Rust Belt, SW PA
[Re: Silver70]
#1832094
05/22/15 12:33 PM
05/22/15 12:33 PM
Silver70
Rust Belt, SW PA
[Re: Silver70]
#1832095
05/22/15 12:35 PM
05/22/15 12:35 PM
Silver70
Rust Belt, SW PA
[Re: Silver70]
#1832100
05/22/15 12:37 PM
05/22/15 12:37 PM
Silver70
Rust Belt, SW PA
And the donor and roof section
[Re: Silver70]
#1832103
05/22/15 12:39 PM
05/22/15 12:39 PM
Silver70
Rust Belt, SW PA
And with a little help setting in place, the roof section went on fairly easy
[Re: Silver70]
#1832106
05/22/15 12:41 PM
05/22/15 12:41 PM
Silver70
Rust Belt, SW PA
All welded at pinch weld and so on... and new quarter starting to be installed
[Re: Silver70]
#1832108
05/22/15 12:42 PM
05/22/15 12:42 PM
Silver70
Rust Belt, SW PA
Quarters fit so good, goodmark, that I got them and the deck filler done in an afternoon... still some welding to finish, but more than happy with how well it went
[Re: Silver70]
#1832115
05/22/15 12:46 PM
05/22/15 12:46 PM
Silver70
Rust Belt, SW PA
That's as far as I got on it in the last week or so now. My garage is too full so have to work on it outside. Weather didn't agree yesterday.
I can say it wasn't the easiest conversion, but definitely not the most difficult either. I still have to change the roof skin. I wanted to use a structure that was all one piece to keep things square.
I was told I was crazy for taking doing this... but I don't think it was any worse than doing full frame rails and such.
[Re: Silver70]
#1832132
05/22/15 01:10 PM
05/22/15 01:10 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Very nice! I'd have done the same thing...if I had your welding and fabrication skills, lol.
[Re: Silver70]
#1832150
05/22/15 01:41 PM
05/22/15 01:41 PM
Silver70
Rust Belt, SW PA
I already have two 2 doors, but both I couldn't justify cutting/modifying to do what I wanted with. The satellite is already redone and way too original... my roadrunner is 95% plus original sheetmetal. So figured with this I'd have no problem putting in a rollbar, minitub it and so on. It will be a street car, but more of a track car. It really was easy in my mind, just a ton of cutting and drilling. I did the apillars to the factory spots. The rear panels to rocker and wheel houses, they were in between, so I overlapped and welded in place... reason for the seam sealer. That and I wasn't going for a perfect factory look. This was far less work than drilling thousands of spot welds to use the good panels on a rusty car. I learned how to do body work on wrecked cars. Doing clip, rad supports etc. So this was really no different than that. When it's done it will look just like any other 2 door and you'd really have to look to tell it was a 4 door... or look at the vin
[Re: Silver70]
#1832256
05/22/15 03:34 PM
05/22/15 03:34 PM
Posts: 5,268 NY
70440+6bbl
NY
Wait, who's this fool that "talked" you into that car???
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1832522
05/22/15 11:01 PM
05/22/15 11:01 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Ha! At first I thought yeah that guy is nuts. But really this is a great project and another 69 stays on the road. Kudo's!
Sheldon
Sheldon
[Re: RUNCHARGER]
#1832637
05/23/15 02:12 AM
05/23/15 02:12 AM
Silver70
Rust Belt, SW PA
Sheldon When I was all in pieces I felt like I was nuts. Had it been solid and not needing rust repair, I probably would have left it a 4 door. But 2 of the 4 doors are damaged, floors front to back and the rear window opening was shot including the corner sections that are part of the quarters. Then the package tray was all hacked up too.
[Re: Silver70]
#1833485
05/24/15 10:14 PM
05/24/15 10:14 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
You're a better man than I. I'd have bet money you couldn't convert that vintage. Whole lot more difficult than the early-mid 60's b bodies. Well done!
Lead, follow or get the hell out of the way
[Re: Silver70]
#1851280
06/17/15 08:12 PM
06/17/15 08:12 PM
Posts: 836 Up a holler, down a crick
booger
A frankenbee sold on ebay once, they'd split a superbee horizontally to get rid of lower body rust and welded that to the bottom from a 4-door.
It has a WM23M9A VIN on it when finished.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
