Battery cut off switch wont kill batery. HELP!
#1830310
05/19/15 08:47 PM
05/19/15 08:47 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
I installed the Flaming River push pull cut off switch. Kills all the lights just not the motor! What am i missing and what am i supposed to do to fix it? Thanks joe
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Battery cut off switch wont kill batery. HELP!
[Re: bigblk66_coronet]
#1830335
05/19/15 09:28 PM
05/19/15 09:28 PM
Posts: 740 WA
JD Dart
WA
If you have just a two pole switch you will need to have the alt cable go all the way back to the battery. That way when you turn it off the alt can only feed the battery and the car will die.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: JD Dart]
#1830338
05/19/15 09:35 PM
05/19/15 09:35 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
If you have just a two pole switch you will need to have the alt cable go all the way back to the battery. That way when you turn it off the alt can only feed the battery and the car will die. that
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: JD Dart]
#1830342
05/19/15 09:38 PM
05/19/15 09:38 PM
bigblk66_coronet
illinois
I have a 10 gauge wire running from the aternator to the battery already. Some guys on Yellow bullet say i need a relay to kill it. Dont know dont really care anymore. Instructions were an absolute joke. Told nothing
440w/727
#1830360
05/19/15 10:05 PM
05/19/15 10:05 PM
Posts: 740 WA
JD Dart
WA
There has to be something piggy backing on that wire. Do you have anything else spliced into your 10 gauge wire?
#1830407
05/19/15 11:22 PM
05/19/15 11:22 PM
70AARcuda
las vegas
you need to wire it to the battery side of the switch ...so went to turn the switch off the alternator does not feed the ignition...
got 3 cars wired that way..
Tony
#1830447
05/19/15 11:53 PM
05/19/15 11:53 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Yep run the Alt wire to the battery side of the switch. By wiring it to the battery you are not isolating it.
[Re: 70AARcuda]
#1830453
05/19/15 11:55 PM
05/19/15 11:55 PM
bigblk66_coronet
illinois
Nothing piggy backing on that wire and it is wired on the battery side of the sitch. It wont shut the car off if you push it in. But if you try to start the car with it pushed in it wont start.
440w/727
#1830455
05/19/15 11:58 PM
05/19/15 11:58 PM
bigblk66_coronet
illinois
I have the wire leading to the alt wire to the same post on the switch as the pos battery cable. Is that right?
440w/727
[Re: Al_Alguire]
#1834305
05/26/15 01:24 AM
05/26/15 01:24 AM
Posts: 916 Arizona
Chucklehead
Arizona
Yep run the Alt wire to the battery side of the switch. By wiring it to the battery you are not isolating it. OK That has me confused(not to hard to do) What is the difference between the battery post and the switch post if the battery cable runs from the post to switch post? Would not both locations be connected by the battery cable?
Still Broke
#1834313
05/26/15 01:42 AM
05/26/15 01:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 10 gauge wire running from the aternator to the battery already. Some guys on Yellow bullet say i need a relay to kill it. Dont know dont really care anymore. Instructions were an absolute joke. Told nothing You can do it with a relay.. not the simplest way to do it... you run JUST the single lead from the alt output(the big wire) all the way back to the battery side of the master switch... it will kill it.. are you running any kind of continues duty relay for anything
#1834550
05/26/15 02:24 PM
05/26/15 02:24 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
The preferable setup is the two-pole (four terminal) cutoff switch (one for battery cable, one for alternator cable). If you have the more common single-pole (two terminal) switch, then run the alternator cable back to the battery side of the switch. Then when the switch is pulled, the alt will only be charging the battery, not running your ignition, fuel pump etc. and the car will die. Please note my earlier warning about current back-feeding through the alternator dash light - this is a known problem with MSD and other electronic ignition setups.
The only problem with the single-pole switch is that the alternator cable is hot at all times, since it's connected directly to the battery. This is OK by NHRA rules which specify that the engine must shut off when the switch is pulled... although there is some heated discussion about the "spirit vs. letter of the law" on FABO.
So I would highly recommend that you put a fuse rated for your alternator max output) close to the battery end. If that large wire gets damaged by fraying or an accident and it shorts to the body, it could start a fire very easily.
#1834793
05/26/15 08:14 PM
05/26/15 08:14 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The ONLY way this happens, is that your ignition system is still getting power from somewhere after the switch is pushed. Now assuming that you DO have the kill on the positive lead... with the switch pushed, obviously that power is not coming from the battery.........so that only leaves SOMETHING attached to the alternator circuit somewhere. Since none of us can see the car, you are going to have to track it down. Start chasing wires and circuits is the only answer. You say the ONLY thing on the lug of the alternator is a big wire running to battery and NOTHING else. If that is true, the "field" wiring is supplying power to the ignition. Appears you must have a Mopar alternator, so to "fix" it, you will have to break the field circuit as well when you kill it. That is why some were telling you to use a relay. The field circuit runs through the relay and battery power switches the relay on. Kill the battery, relay opens, breaks field circuit
Monte
#1834843
05/26/15 09:30 PM
05/26/15 09:30 PM
Posts: 11,632 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A one wire alternator with the power cable run to the battery side of the master switch would be an easy solution.
#1834854
05/26/15 09:52 PM
05/26/15 09:52 PM
Monte_Smith
North Alabama
True, but judging by the signature line of the OP, this is a fairly stock piece and not a RACE car, so doubt he wants to do that. Guess the reason for switch is battery is in trunk
Monte
