Re: M PURPLE SHAFTER HYD CAMS.
[Re: MIKES_DUSTER]
#1827305
05/15/15 03:35 PM
05/15/15 03:35 PM
Posts: 5,167 CT
GTX MATT
CT
I don't believe the .533 is available anymore, its really too big for a hydraulic anyway. If he wanted to stay with Purpleshafts the next step would be the .557 solid cam, which would likely run about the same. It specs bigger but once you subtract the lash you've got about the same duration, .010 more lift, and 2 degree wider LSA.
Are the heads ported? And is he running the old 108 LSA 509 or the 114 LSA 509? You're not going to get much bigger than the 509 on a hydraulic, you might get a bit more lift with a modern profile, but thats it.
[Re: MIKES_DUSTER]
#1827332
05/15/15 03:53 PM
05/15/15 03:53 PM
Posts: 4,457 Washington
madscientist
Washington
Call Jim at Racer Brown and see what he has. Or Cam Motion. I like Jim at RB a lot. You can get a bit bigger on the hydro but I agree that he should be usings solids. He shopuldn't lash the valves more than once a year. And he could pay someone to do that.
FWIW...other than idle...I'm not a wide LSA guy...especially with production style heads.
[Re: MIKES_DUSTER]
#1827359
05/15/15 04:32 PM
05/15/15 04:32 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Hughes have some good grinds as well. A street car with 4.56 gears.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: MIKES_DUSTER]
#1827405
05/15/15 06:15 PM
05/15/15 06:15 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Performance wise, what would be better, 108 or 114???? It has a 727, 3800 converter and 4.56's. The motor is at the machine shop now getting buttoned up soon. The 108 would be better performance wise. More low end as a result of the intake valve shutting sooner. Further I would install the cam about 102* to 104* ICL, for even more streetable performance if he Has enough p/v clearance.
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
[Re: MIKES_DUSTER]
#1827423
05/15/15 06:46 PM
05/15/15 06:46 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Howards make some very nice .904 based camshafts for a 440...and very nice priced from Summit racing.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
