electric pump: Oil changes when removing fuel pushrod #1823454
05/10/15 02:42 PM
05/10/15 02:42 PM
usa
smos001 Offline OP
smos001  Offline OP
usa
I think I know the answer but...
I removed the mechanical fuel pump pushrod when I switched to an electric fuel pump.
Does this change the oiling at all in the engine as now the rod is not there? 383 engine.
my guess is that it was splash oil on the rod. So removing the rod should not make a difference.
curious,
Re: electric pump: Oil changes when removing fuel pushrod [Re: smos001] #1823459
05/10/15 02:45 PM
05/10/15 02:45 PM
Kirkland, Washington
Pacnorthcuda Offline
It will not make a difference.
