Re: Do I need to shorten my driveshaft?
[Re: gts1]
#1823465
05/10/15 02:52 PM
05/10/15 02:52 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Generally 3/4" to 1" is the norm...IMHO 1/2" is really pushing it, should it bottom out on on suspension travel it may crack the tailshaft, is that 1/2" you have without the end seal boot/lip?
[Re: DAYCLONA]
#1823519
05/10/15 04:45 PM
05/10/15 04:45 PM
RapidRobert
me too I think 1/2" is pushing it exp with a stick. Very likely you could move the eng/trans forward a hair & shim the front rear spring shackles back a bit to gain enough (3/4" is good) WO having to redo the shaft
[Re: gts1]
#1823726
05/10/15 10:29 PM
05/10/15 10:29 PM
RapidRobert
I was assuming it was the common flat aftermarket seal. With the one you have if you butt the shaft all the way forward do you have 1/2" or more than 1/2"?
[Re: gts1]
#1824386
05/11/15 07:30 PM
05/11/15 07:30 PM
RapidRobert
butt the shaft forward & see if you have 3/4-7/8" play cuz that is what those parts will enounter & if so you're good. iirc with that type you're already set but I would check unless someone chimes in that you are OK from the pic/descrip
[Re: gts1]
#1824691
05/12/15 12:31 AM
05/12/15 12:31 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Unless you have something extreme like a car sitting super high in the rear and driving it compresses things alot. Less than 1/2 will work.
When the front leaf spring is parallel with the rocker panels. This is just about as forward as the yoke will ever be. Now lift the car by the frame and allow the springs hang until the shock absorbers reach their limit. Not many circumstances will allow the yoke to go in further than that.
I had a leaf sprung Dodge truck. With grease smeared on the yoke. I drove it, raced it, power shifted it, towed a trailer with it and found 1/4" of travel witness by the grease line.
