Page 2 of 3 1 2 3
Re: blow by temp fix [Re: deaks] #1822831
05/09/15 06:01 PM
05/09/15 06:01 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
topic is..... BLOW BY FIX. I ran dirt track series for many years. when we had a lot of laps on an engine and were loosing oil by the rings , we used engine restore in the oil and it did help some. http://www.amazon.com/Restore-00016-8-Cy...600a41.70486092
Re: blow by temp fix [Re: ek3] #1822841
05/09/15 06:10 PM
05/09/15 06:10 PM
Tacoma, Washington USA
Adam71Charger Offline
Gee and here I thought it blowby temp fix?
Re: blow by temp fix [Re: deaks] #1823069
05/09/15 11:55 PM
05/09/15 11:55 PM
Andrews,In. U.S.of A.
67_Satellite Offline
http://www.restoreusa.com/ Have used this and there was less blow by coming out of the breather than before. Could smell the difference in the car.(yes, it was tired and abused) NOT a rebuild in a can, but it did help.
Re: blow by temp fix [Re: deaks] #1823096
05/10/15 12:20 AM
05/10/15 12:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By deaks
Sorry i didn't reply DC, there's an 8 hr difference between us and i've been busy working today. I've tried nothing yet but i may have the exhaust evac parts in the garage.
Here's a pic of one of the plugs, oil on the threads but dry and biscuit brown everywhere else.
Mick
Burning oil is a shiny black coating on the plug, what you show, on that one plug, is pretty much normal looking.
What do the other 7 show?
Don't be the exception.
Re: blow by temp fix [Re: 67_Satellite] #1823108
05/10/15 12:39 AM
05/10/15 12:39 AM
https://board.moparts.org/ubbthreads/ubbt...tml#Post1523374 Thought this question sounded famililar.
Re: blow by temp fix [Re: 67_Satellite] #1823206
05/10/15 04:36 AM
05/10/15 04:36 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Looks like everyone has things pretty well covered.
I installed the Moroso Crankcase Evacuation Kit around 2002 on my Charger. It pulls a fair vacuum at idle and improves with increased RPM. I mounted Baffle Plates inside the valve covers beneath the breathers to reduce/eliminate oil loss.
http://www.moroso.com/eb/web/instructions/25900_inst.pdf
Liked the end results so much, I made my own kit from hardware store 1/2-inch pipe, Smog Pump Check Valves, vinyl tubing, breathers and grommets, mounted to the headers, for use on the V8 engine in my CJ5 Jeep.
As suggested, people think about the air/fuel mixture above the piston, but may forget about the air below the piston in the crankcase / cylinder block. That air has to move around in the crankcase and energy is wasted in the process and it adds to crankcase windage.
Someone figured this out many years back, maybe it was a NASCAR engine builder, at least that was what I had heard back in the day, but maybe it was some amateur racer? By connecting a vacuum pump and creating a partial vacuum in the crankcase, horsepower increased.
Bracket racers used to convert Smog Pumps into vacuum pumps for a similar purpose.
In any event, there are benefits to creating a partial vacuum in the crankcase.
Re: blow by temp fix [Re: Adam71Charger] #1823212
05/10/15 05:08 AM
05/10/15 05:08 AM
E
ek3 Offline
ek3  Offline
E
I left that out because I knew someone like you would need to reply and add something meaningful. be sure to add the space in blow-by!
Re: blow by temp fix [Re: deaks] #1823245
05/10/15 10:04 AM
05/10/15 10:04 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Pour in Restore and hope for the best.
I want my fair share
Re: blow by temp fix [Re: deaks] #1823348
05/10/15 12:25 PM
05/10/15 12:25 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I took my challenger to the track monday for the first time since i bought it a few weeks ago and it is pushing a bit of smoke out of the exhaust on one bank at high rpm. It has good oil pressure and sounds fine, makes pretty good power, unfortunately i haven't got a lot of time to mess with it at the moment, so wondered if there's anything i can stick in there to stop it smoking untill i get time to pull it out. I intend to do a comp test in the next week or so just to verify the problem or not ?
Mick
Are you running mufflers?
Abe Lincoln
Re: blow by temp fix [Re: deaks] #1823460
05/10/15 02:45 PM
05/10/15 02:45 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Yes they finish at the axle, it's a street strip car, full interior.Why do you ask ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: blow by temp fix [Re: deaks] #1823474
05/10/15 02:57 PM
05/10/15 02:57 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Does the probe have to go in the collector, or can it go in the front of the exhaust ?
best 60ft 1.36
Re: blow by temp fix [Re: deaks] #1823507
05/10/15 04:30 PM
05/10/15 04:30 PM
ky.
K
kenworth_goose Offline
K
ky.
Here's an idea! why don't you try driving it easy since you only have an issue when you take it to the track?
Re: blow by temp fix [Re: deaks] #1823977
05/11/15 04:35 AM
05/11/15 04:35 AM
D_C Offline
D_C  Offline
When you say "probe" are you talking about the "Pan Evac" system or is it some measuring probe?
A Pan-Evac doesn't have a "probe" but what it does have is a 1/2-inch metal pipe, the same as you can buy at a hardware store. The weld-in pipe is threaded on one end (to attach the exhaust check valve) and the other end is cut at a 45-degree angle. It is this cut end that is positioned in the collector such that the exhaust stream passes over this cut end drawing air from the crankcase into the exhaust stream.
It works much like an old fashioned perfume vaporizer, air passing over the end of a tube draws perfume into the airstream.
As for required positioning of the pipe, from testing and experimentation the optimum placement is in the collector. If you weld the pipe in farther downstream, the effectiveness is reduced.
If it is some other "probe" you are speaking of, please excuse my explanation.
Re: blow by temp fix [Re: dart4forte] #1824037
05/11/15 11:22 AM
05/11/15 11:22 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Mick
If you are running an evac type system and mufflers you'll have a back pressure problem. Evac systems are designed for an open system. You may have too much crankcase pressure which is pushing up through your rings. Try unhooking the evac and run some filters and see what happens.
Abe Lincoln
Re: blow by temp fix [Re: deaks] #1824287
05/11/15 04:45 PM
05/11/15 04:45 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
DC
I meant the steel tube, i'd rather it went just behind the collector at the front of the exhaust and out the side facing forward at 45 degrees. That way i dont have to pull the headers out. Do you run your headers open at the track or corked up ?
Dart4forte
I actually have caps near the front like a max wedge exhaust, although i ran it corked up the other week.
best 60ft 1.36
Re: blow by temp fix [Re: deaks] #1824308
05/11/15 05:16 PM
05/11/15 05:16 PM
D_C Offline
D_C  Offline
I generally leave the mufflers ON and always on the street for the Charger, and mufflers always on the Jeep CJ5.
The Moroso Instructions are fairly explicit about placement of the pipe.
DRAG RACE APPLICATION
1. Remove valve covers and drill a 1-1/8” hole in each cover. On all Moroso “Stamped” Valve Covers, the holes provided will work perfectly. When determining hole location for all other covers, try to find a flat surface that is not directly over a rocker arm oil hole.
NOTE: Separators must be installed in a position at right angles to the top of the valve covers to function effectively. See Fig (1)
2. Before installing rubber grommets, remember to cut the bottom ”seal area” off to allow the separator to work. Lubricate the inner surface of the grommet with a touch of oil or grease and twist in the separator. The fit should be tight to help hold crankcase vacuum.
3. Drill a 7/8” hole in the right and left collector directly behind the transition area shown in figure (2). Check valve installs on the top of the collector.
4. Place check valve probe at the proper depth and angle per drawing and weld all the way around for a complete seal.
5. Use a 5/8” high heat or high pressure hose to complete installation. See Fig (3)
I suppose you could experiment with trying to mount the Pipe as near the flange as possible and with a short collector it might work, but then again, it may not be very effective as compared to having the Pipe at the merge-point where all the header tubes meet in the collector.
I know it was a fair amount of work to remove and drill holes in almost New headers, but though I had similar thoughts about mounting the pan Evac pipe in the exhaust pipe instead, from all I read, I didn't think that would be sufficiently effective. Since this isn't a true vacuum pump, I figured I needed the best pipe placement possible and mounting it in the collector was the only recommended placement. I didn't want to go to all that trouble and have it not work.
Re: blow by temp fix [Re: D_C] #1824329
05/11/15 05:47 PM
05/11/15 05:47 PM
D_C Offline
D_C  Offline
Mr Gasket Pan Evac Installatin Instructions
The drawing in the instructions indicates correct placement of the pipe.
Re: blow by temp fix [Re: deaks] #1824420
05/11/15 08:11 PM
05/11/15 08:11 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
The moroso instructions show the pipe on the top of the collector, i will weld it like your pic because i can do that with the headers on.
Do you run pcv's as well ?
best 60ft 1.36
Re: blow by temp fix [Re: deaks] #1824446
05/11/15 08:42 PM
05/11/15 08:42 PM
D_C Offline
D_C  Offline
Yes, I use PCV connected to the carburetor base as well as the Pan Evac (both).
When choosing where to mount the Pipe in the Header Collector, keep in mind that the Check-Valve and a Hose need to be connected to the pipe end. If the Pipe points toward the ground you might have ground clearance problems. If you mount the pipe on top you may have chassis clearance problems. Before you remove the headers, look at choosing the best mounting location.
Generally speaking, to have a good straight hose connection it is good to mount it on top of the collector or offset top to the right or left for good hose routing.
Re: blow by temp fix [Re: deaks] #1824800
05/12/15 08:47 AM
05/12/15 08:47 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I'm thinking of connecting at a 45 degree angle on the side towards the sill of the car, that way i can fit it in situ.
What's your feelings on the argument re not using evac on a street car.
Thanks for all your help as well DC.
best 60ft 1.36
Page 2 of 3 1 2 3
