68 R/R MM1 paint questions. #1821977
05/08/15 06:06 PM
05/08/15 06:06 PM
W
Wagonman1967 Offline OP
W
Howdy All, I am doing research on my 68 R/R and need to find a place to get paint. MM1 is on the fender tag and should be Bronze Metalic or Turbine Bronze. I have used the Summit brand of paint on other cars and was wondering if anyone has use their Bronze color ?? Is it close to the OEM color or am I wasting time with it?? Any thoughts appreciated.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: 68 R/R MM1 paint questions. [Re: Wagonman1967] #1822187
05/08/15 09:58 PM
05/08/15 09:58 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Sherwin Williams shows a formula for it, which probably means PPG and others do as well. The Summit paint probably won't match unless it's that exact formula. You could order a quart to try some sprayouts, but I'd bet it's not close. Maybe it is if you aren't stuck on factory correct...
Another option: https://www.carpaintonline.com/paints-byoem.php?PPGCode=60492&PNId=13935&OEMCode=mm1
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
