Best Sealing LA 360 Iron Head Exh Header Gaskets? #1818252
05/04/15 05:33 AM
05/04/15 05:33 AM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
Which are the best sealing header flange gaskets for a Factory Cast Iron Head LA 360 Cubic Inch engine?
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1818276
05/04/15 08:45 AM
05/04/15 08:45 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I use these on my turbo car... Little high temp silicon and I have NEVER had a leak with them.
http://m.summitracing.com/parts/php-66037
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1818339
05/04/15 11:22 AM
05/04/15 11:22 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have great luck with the cheap white mr gasket ones. I have blown one out in about 18 years.
You might also look up some from a company called "Bison" if they are still around they make super heavy duty gaskets.
68 Barracuda Formula S 340
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1818693
05/04/15 06:50 PM
05/04/15 06:50 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Copper rtv, no gasket.
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1818699
05/04/15 07:03 PM
05/04/15 07:03 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The ones that came with my TTI's have been on for over 12 years,
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1818852
05/04/15 09:46 PM
05/04/15 09:46 PM
D_C Offline OP
D_C  Offline OP
Thanks for the replies and suggestions. Anyone tried the SCE Copper embossed or Steel Fiber?
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1821435
05/07/15 11:39 PM
05/07/15 11:39 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
http://catalog.remflex.com/category_s/79.htm
These are working great for me so far. Put a set on my 440 pickup, 4.3 gmc and my parent's 360 dakota. No problems with any of them.
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1821450
05/07/15 11:51 PM
05/07/15 11:51 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Fel-pro part #1413
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1821454
05/07/15 11:54 PM
05/07/15 11:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'm telling you those 3 layer soft aluminum ones I posted are hands down the best ones you can buy. The soft multi layer conforms to any warped flange you can throw at it.
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1821560
05/08/15 01:23 AM
05/08/15 01:23 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The best gasket will not seal a warped flange.
A recommendation was made in another thread, read the 2nd reply
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1821572
05/08/15 01:42 AM
05/08/15 01:42 AM
Washington
skrews Offline
skrews  Offline
Washington
Remflex #1
Perceys carbon X #2
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: D_C] #1822770
05/09/15 04:37 PM
05/09/15 04:37 PM
Central NC
gch Offline
gch  Offline
Central NC
I have welded and sanded header flanges before to get a smooth flat surface.That being said the best header gasket I have found is the plain old blue fel-pro ones.
Re: Best Sealing LA 360 Iron Head Exh Header Gaskets? [Re: gch] #1822778
05/09/15 04:47 PM
05/09/15 04:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
same here
