Dakota Seat Removal question #1820220
05/06/15 01:52 PM
05/06/15 01:52 PM
Bradenton, Fl 34203
Kilroy was here Offline OP
Bradenton, Fl 34203
Ok, the factory diagram says 4 bolts, i did that, the seat is loose. However, there seems to be 2 pins that holds the console frame to the seat frame. I'm ready to grind it off, unless you know of a better way.
All this to get to a broken wire on the seat belt latch.
Re: Dakota Seat Removal question [Re: Kilroy was here] #1820289
05/06/15 03:40 PM
05/06/15 03:40 PM
Bradenton, Fl 34203
Bradenton, Fl 34203
Drilled out pin, and a 5th bolt. Seat is out.
