Page 15 of 21 1 2 13 14 15 16 17 20 21
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: cudaman1969] #1370152
03/11/15 05:42 AM
03/11/15 05:42 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
The 5.7 is also a tad narrower - but when travelling from small to larger openings, that type of 'step' is not going to interupt flow.
The step caused by the more rectangular port face of the 5.7 certainly woulde have created flow issues...hence my marginal gasket matching attempt.
Idealy you'd probably take down the inside of the runner for really improved flow.
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: Moparmal] #1370153
03/11/15 07:40 AM
03/11/15 07:40 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
While the idea that a rapid transition to a larger cross-section doesn't hurt flow seems logical, it turns out that the exact opposite is actually true. A large portion of what I do for a living involves fluid flow analysis and what I have found is that an abrupt enlargement can actually be more harmful than an abrupt contraction in cross-section due to the higher velocity and the turbulance and flow separation that occur at the transition. What this means is that you will want a smooth, long transition with any change in cross-section area.
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: Kevins493] #1370154
03/12/15 11:14 PM
03/12/15 11:14 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Been going over my 5.7 engine and have a few things to talk about. First one is the heads, seems they can be used on either side, not having to use a left and right. In fact if buying new head just buy two driver side if not using the egr. The reason i tried this i was thinking of using a turbo with the stock manifolds so its just a mater of reversing the heads. There are a few bolt holes to drill and plug the egr hole. The measurement to outside of manifolds is 29 inches, enough to fit inside an a-body frame. I put the intake back on and no issues there and the push rod holes are in the right place. Of course i don't know about the newer heads, just 5.7. The oil passages are a lot of 90 degree turns from the oil pump to the mains so a long carbide burr ball could ease those sharp corners and be opened up a little. This should aid flow to the crank. As i see more I'll keep posting.
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: cudaman1969] #1370155
03/13/15 09:20 AM
03/13/15 09:20 AM
Canada
onig Offline
onig  Offline
Canada
In regards to the left and right head.
EGR is one issue, just plug as you mentioned.
I have a set of Apache heads and are L & R.
It is the oil drain-back holes that you need to look for, I am guessing that the 5.7 are the same as well. But check to make sure. I have circled where the oil hole is, as you can see because of this they are not interchangeable. I believe the hole can be drilled as there is material there to make a hole.
Also on these heads the exhaust manifold holes are drilled differently but can easily be drilled and taped as there is plenty of material there as well.
Just check your 5.7 heads to make sure all is OK with the oil drain-back.
Let us know what you find.
I have 5.7 but it is still sitting on a shelf.
69 Dart
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: cudaman1969] #1370156
03/13/15 09:21 AM
03/13/15 09:21 AM
Canada
onig Offline
onig  Offline
Canada
By the way, what year is that engine and what did it come out of?
69 Dart
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: onig] #1370157
03/13/15 11:24 AM
03/13/15 11:24 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
06 and 07. You are right, the drain back hole would have to be drilled. The problem I see is closing the other hole since the head gasket is dead center. Plugged and milled flat. Plug one and drill another or make headers, not sure what would be easier for most people. At least with headers they can be placed in the best spot. Thank you Chrysler.
The water hole would need grinding too.
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: cudaman1969] #1370158
03/16/15 11:51 PM
03/16/15 11:51 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I have some questions on the 5.7 engines. Will the heads, intake, cam, oil pump, and timing set from a 2003 truck engine interchange on a 2014 short block truck engine ? I have both engines complete but the 2003 engines oil pump failed and wiped out the rod and main bearings.
I was hoping I could take the heads and freshen them up on the 2003 engine and bolt them and the intake on the 2014 motor. I'm guessing since the 2014 engine has the vvt that the cam shaft, lifters, pushrods, timing set would be different ? Would the block and pistons be different ? Not sure how much they changed the block, what will and won't plug in, or if all the accessories on the front of the engine from the 03 will bolt on the 14 ? I'm just trying to save some time and money by using what I have. Otherwise I'll have to rebuild the 2003 motor while the 2014 motor takes up floor space in my garage!
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: krw71ragtop] #1370159
03/17/15 03:46 PM
03/17/15 03:46 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Lifters: Keep the '14 lifters, they support higher lift with MDS, and can be used to replace lifters in 08 and older 5.7's.
Cam: No
Timing Set: No
Pushrods: No, Eagle head valves are taller.
Intake/Head pair work together. Fitment on a 09+ block? Don't know, if they do the older heads have larger chambers and will drop compression. I'd recommend Eagle intake/heads over the older 5.7's. Also the Eagle truck intake, I believe, has short/long runners controlled by the PCM.
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: New Eddy dual quad vs old DQ Modman - first notes [Re: StricNine] #1370160
04/04/15 09:36 PM
04/04/15 09:36 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Make sure your machine shop of choice has a torque plate for the block you are using. DAHIK
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1812094
04/26/15 12:40 AM
04/26/15 12:40 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Don't forget the oil galley plug in the front of the engine, didn't know it existed until today....
Mopar to the bone!!!
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1816456
05/01/15 02:59 PM
05/01/15 02:59 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Can the stock cams be reground?Could save some cash that way I would think. Probably have to harden the lobes, but they do that to the new ones anyway right?
Re: Gen III Hemi, please post things to avoid and know.. [Re: cudaman1969] #1816976
05/02/15 10:35 AM
05/02/15 10:35 AM
gregsdart Offline OP
Hughes had some regrinds listed on their web site. There are limits, due to the stock lobe dimensions and LSA . Depending on what you want to do, a custom cam may really be needed. In a deal like my build, (stroker, big heads, not as worried about torque below 2,500, totally programmable computer) it only makes sense to have one cut, or in my case grab a drag pack cam if you can find one cheap!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1817834
05/03/15 05:01 PM
05/03/15 05:01 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
If you add external oiling to the block, the fittings may interfere with the back of the alternator
Re: Gen III Hemi, please post things to avoid and know.. [Re: ntstlgl1970] #1818204
05/04/15 12:24 AM
05/04/15 12:24 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is why I used a remote filter adapter instead of the block off plate.
Re: Gen III Hemi, please post things to avoid and know.. [Re: 72Swinger] #1818871
05/04/15 09:00 PM
05/04/15 09:00 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
What did i do wrong ?
Re: Gen III Hemi, please post things to avoid and know.. [Re: sogtx] #1818906
05/04/15 09:31 PM
05/04/15 09:31 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
I guess u cant believe all on the net ..
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1818964
05/04/15 10:43 PM
05/04/15 10:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Those idlers are for a VVT engine which has all the accessories spaced out further, about 1/2".
Re: Gen III Hemi, please post things to avoid and know.. [Re: 72Swinger] #1819028
05/04/15 11:21 PM
05/04/15 11:21 PM
USA
hudsonhornet7x Offline
USA
Does anyone know the difference between an apache head and a hellcat?
I am aware they are a different alloy, but what about valves, springs, flow, etc. Thanks!
Re: Gen III Hemi, please post things to avoid and know.. [Re: gregsdart] #1819057
05/04/15 11:50 PM
05/04/15 11:50 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
I have one set of 5.7 heads where the valve seats( intakes) came out. Any procedures on making sure they stay put in my other set, these are 08 heads.
Re: Gen III Hemi, please post things to avoid and know.. [Re: hudsonhornet7x] #1819289
05/05/15 11:49 AM
05/05/15 11:49 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
The hellcat heads don't interchange, the intake manifold bolt pattern is different to mount the supercharger.
look at this picture from a hellcat supercharger on ebay
http://i.ebayimg.com/00/s/OTA0WDE2MDA=/z/lDMAAOSwBahVLVwH/$_57.JPG
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/e9MAAOSwBLlVKmRn/$_57.JPG
I save the pictures before they disappear. It does look like you could have the intake bolt pattern drilled to match the eagle/apache/6.1L heads since the bosses are cast into the head but undrilled.
