Re: 46 Plymouth [Re: bigdad] #181848
02/26/09 12:52 AM
02/26/09 12:52 AM
Puyallup, WA
Joe-Bob Offline
Joe-Bob  Offline
Puyallup, WA
Ya know, I just keep studying what everyone else has, or is doing and try to figure what my best angle would be. At first I thought the dropped uprights and a disc brake kit would be the way to go. Simple and not too expensive... but when you price them both out they run about $1100.00. The JW Rod Garage catalogue came today and their kit is about $1700.00 and you get rack and pinion steering and all new parts. Seems like the better deal to me. It looks like about the same deal as the fat guy's stub with a little more labor on my part for a lot less money. Would that be your opinion as well? Or is there some factor I'm overlooking between the two that I should be concerned about?
By the way, your car is in the weeds. Did you bag it? It really grabs your attention.
Re: 46 Plymouth [Re: Joe-Bob] #181849
02/26/09 10:41 AM
02/26/09 10:41 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
No,I had dropped spindles on the front and the coil overs cranked down in back .
Not real practical but, looked cool
"stance" is everything
If you are up to the task of cutting, welding,etc
Yeah, its a good option ..
Those cars have odd frames, most you can just add a crossmember , these due to the taper and design in the stock spring pocket area, no way to do it without cutting it off and replacing it with something ..
The quickest , least amount of fabrication work
is to use the uprights, shock mounts, etc
from www.fatmanfab.com
The stub somewhat eliminates some of the guess work out, you set it in right place and all the rest will be in right spot ..
Its the most expensive to purchase and to ship
I used a Fatman crossmember on my truck
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 46 Plymouth got it home *DELETED* [Re: bigdad] #181850
03/08/09 06:47 PM
03/08/09 06:47 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Post deleted by moparpollack
Re: 46 Plymouth got it home *DELETED* [Re: moparpollack] #181851
03/15/09 01:44 AM
03/15/09 01:44 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
does any one know the first year a dakota came with rack and pinion ? im searching for answers to doing my 40 dodge as well,,,the current dakota uses stuts,,so i believe 2004 and up are out of the question,,,but i thought 2000 was the first year for rack and pinion in a dakota,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 46 Plymouth got it home *DELETED* [Re: fstfish66] #181852
03/15/09 08:52 AM
03/15/09 08:52 AM
85086
Lil Herman
Lil Herman
85086
All 2WD were rack and pinion.
Re: 46 Plymouth got it home *DELETED* [Re: moparpollack] #181853
03/16/09 08:36 AM
03/16/09 08:36 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
all 2 wd including the first generation ?? 1987
2015 cherokee
2013 R/T classic
Re: 46 Plymouth got it home *DELETED* [Re: fstfish66] #181854
03/16/09 09:03 AM
03/16/09 09:03 AM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
The Dakota I used was an '87 and it had rack and pinion. It didn't have a front sway bar, but a bolt in crossmember.
Re: 46 Plymouth got it home *DELETED* [Re: 49wayfarer] #181855
05/05/09 01:20 AM
05/05/09 01:20 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wel ive done some research,,rack and pinion was an option in 1987,,so both styles are out there steering box or rack,,not all are rack,,
has any one used the stock 1940s ply/dodge ifs,with a fat man rack kit,dropped up rights, and full size front coils ??
my car currently has a fat man rack,cut coils to drop the front,,rides terrible,,anda master power disc conversion,,
my thinking is to keep what i have,and put full size coils back in so i have full travel,and dropped up rights to get the stance,, the car rides hard,,steers great,and the brake kit still needs some tweaking,,, any ideas would be welcome
e mail me please i dont recieve e mails from this site fstfish66@aol.com thanks in advance
2015 cherokee
2013 R/T classic
Re: 46 Plymouth got it home *DELETED* [Re: fstfish66] #181856
05/05/09 10:58 AM
05/05/09 10:58 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
If you are blowing the front end apart again, go with good springs. I don't know if the dropped uprights will get you back to where you want to be with fresh springs. Over on the HAMB, they talk about cutting off the lower control arm plate that holds the spring, and welding it back on under the arm instead of on top, where it is stock.
As for the brakes, tell us what you currently have and what the issues are.
I have a vette master and booster under the floor of my 40, along with 2.5# residual valves to keep the fluid from draining back to the (lower) master. Volare rotors and GM calipers on the front, unknown rotors and GM calipers on the back. Haven't put fluid in them yet...
The 47 has http://www.aajbrakes.com/ in front, early 70s Chrysler wagon drums in back. It also has residual valves, unknown MC, no booster. I've got to get it running, but I'm not happy with the pedal right now. I'll probably jack it up on each end and rebleed. That job was done by a shop, and they %^#$ed me off, so it won't be going back for final adjustments.
Lots of choices on these great cars now, you just have to find the level your skill sets and pocketbook can handle.
The area I'd like to see some experience in is the sway bar. My 40 Plymouth came with one, but I've read that it's not much help. I don't want to redo all the work, so a bigger bar with stronger end links would be the goal. I'd imagine that there is some racing company that makes a bar that would work, but haven't researched it yet or heard of anyone who has done it.
Re: 46 Plymouth got it home *DELETED* [Re: RodStRace] #181857
05/06/09 08:57 AM
05/06/09 08:57 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
well it has 11 inch chevelle rotors,, gm pattern,, i hope to change soon,,,i have replaced the poorly built pedal/master mount with a master power pedal/under floor master cyl,,manual 1 inch bore,,10x2 1/2 drums in the rear,i havent had time to look the car is parked in a trailer right now,,cant get to it,, but i believe the disc pads are glazed,,preventing it from stopping like it should,, i built the brake system on my barracuda and its stops great,,
the fat man dropped up rights are about a 2 inch drop,,i guess i would get coils 2 inches taller then whats in the car now,,,so i have better suspension travel,, or go to a dakota clip,.,ide perfer to make the orignal IFS stuff work,,
2015 cherokee
2013 R/T classic
Re: 46 Plymouth got it home *DELETED* [Re: fstfish66] #181858
05/06/09 10:57 AM
05/06/09 10:57 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
What I plan on doing since my springs are shot too is to take them out, measure the height with the car at full down, full up and at preferred ride height. Then borrow a local racer's scales and measure what the corner weights are.
With that, a spring company should be able to find or make a pair that are just right.
With the engine offset, I'm not sure they will be the same on each side.
Re: 46 Plymouth [Re: bigdad] #181859
05/06/09 07:10 PM
05/06/09 07:10 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You can check on
www.jalopyjournal.com on the H.A.M.B.
I think there is a multi page thread about it there
One other option is
www.fatmanfab.com offers parts to lower the front and to adapt disc brakes and I think its Ply-do that has the rack and pinion parts
I cant find any info for mopars at fatman Ive got a 49 Plymouth I plan to lower and drop in a small block and would like to update the brakes
Re: 46 Plymouth [Re: 76dodgeboy] #181860
05/06/09 10:33 PM
05/06/09 10:33 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
You can check on
One other option is
http://www.fatmanfab.com/catalogpage.php?page=17
right there, call them ..they can give you advice
Re: 46 Plymouth [Re: bigdad] #181861
05/08/09 11:30 PM
05/08/09 11:30 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
im not sure if fat man has a brake kit for the stock spindles,, ply/do does, master power brake does, and another company called ECI has a kit,,,also a guy called scarebird, i may of spelled that incorrectly,, do A GOOGLE search on dodge or plymouth and include the year of car in your google brake search,,
2015 cherokee
2013 R/T classic
Re: 46 Plymouth [Re: fstfish66] #181862
05/09/09 12:24 AM
05/09/09 12:24 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: 46 Plymouth [Re: RodStRace] #181863
05/09/09 12:27 AM
05/09/09 12:27 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i just remembered look for mr streetrod also
2015 cherokee
2013 R/T classic
